Question about Pioneer DEH-1000 CD Changer
Thanks for the assistance
Ohk thanks for that, do u mean the antenna plug may be shorting to body of cd tuner?? and if so shouldnt that be affecting FM frequency?
when i put it on AM i can pick up stations extremely faintly.
wats your thoughts?
    Brigadier General:
  • 6,966 Answers
Hi again richos,
The outside area of the antenna plug would definitely touch the body of the CD/Tuner as it is the ground where the shielding of the cable is soldered to. I was referring to the central point where the active wire is soldered to and is connected to the exposed antenna element.
Another possibility to consider is the orientation/location of the vehicle/antenna (though unlikely).
As to the FM, it would still work (even if shorted) since it operates on MHz (unlike AM in KHz). Some antennas for FM (exclusively) even have a balun (coil) matching which is shorted when tested for continuity.
Have you tried the insulated wire?
Posted on May 25, 2008
Ohk i had an accident so my left side lights are not working i did check all the fuse they still ohk
First check out light bulb to see if it is still good. If good, you will need to follow the wiring back from the bulb into the vehicle checking for broken, pinched or shorted wires.
Dec 30, 2017 | Cars & Trucks
What do I hook the wire for illumination to on the vehical thanks
Illumination can be connected to anything that is live when the lights are on!
The blue antenna wire is live for power aerials, if you do not have a power aerial just tape it up to stop it shorting out! This will not affect your manual aerial connection!
Aug 13, 2015 | Jeep Wrangler 1998 TJ Sport Bestop
How to properly connect the channel Master antenna tuner to my TV so that I can connect an antenna to the tuner. I have the CM-7001. I'm connecting through the HDMI port on the tuner to the HDMI port
Confusing question! The CM-7001 is meant to be used for displays or monitors that have no means of connecting an antenna and don't have a built-in tuner. HDMI to HDMI would be the correct way and make sure you select the proper HDMI port. Or use the other video and audio cable connections.
Sep 03, 2014 | Channel Master CM-7001 ATSC Antenna and...
How do i find the sirius id on the panasonic cq-hr1003u?
The radio does not have a Sirius ID - it is not built in. THe CQ-HR1003u is Sirius READY - meaning... The CQ-HR1003U can control an optional Sirius Satellite Radio tuner by Panasonic (item #133SRT100).
In addition to the Sirius tuner, you will need an antenna and subscription in order to receive Sirius Satellite Radio programming.
Thanks!
Sep 27, 2011 | Panasonic CQ-HR1003U CD Player
When changing radio channels the dx mode appears instead of lo (local) cant get a signal
dx is short for distant. this just makes the tuner more sensitive and should pick up more stations. if it is not picking up stations in dx mode, you either have a bad antenna or a bad tuner.
Mar 22, 2011 | Clarion DXZ545MP CD Player
Lcd tv digital tuner
Welcome to the world of off-the-air broadcasting!
First, be sure you have the TV set up correctly and that is in fact capable of digital tuning. Just because a set was sold as HDTV doesn't mean it has a digital tuner. Small TV sets weren't required to have digital tuning until shortly before the switch from analog. This set may require a digital adapter. If the set does have digital tuning, be sure you have "air" selected and not "cable" for your tuning mode. Also let the set scan for channels.
With digital broadcasting, signal strength is critical. In the analog days, a weak signal would give you a fuzzy picture, but you could see something; with digital, a weak signal means you see nothing at all. You may live in an area where the signal is too weak without using an amplified indoor antenna or putting one on the roof. Your location, other structures around and weather conditions all affect digital reception as well. Many people were (and still are) upset to find that they just couldn't get any channels at all once digital broadcasts took over.
I hope this has been helpful. Thanks for using Fixya!
Jan 31, 2010 | Craig Televison & Video
I own a bose radio/cd (top load) with pedestal. Last night one lightning strike affected power in my home before I could get things disconnected. Now with everything reconnected, my radio FM and AM is very...
The tuner section may have been toasted by the power surge that affected your home. See if there is another option for an antenna connection and try that. If not, then it does not appear you have much choice.
U might want to contact Bose for an authorized factory repair station in your area.
Apr 01, 2017 | Bose Wave Radio
Kenwood Tuner Works Through amp, CD & Ipod dont turn on amp
You have the amplifier remote and power antenna remote installed backward. Switch them. The radio drops power to the power antenna when you choose a source other than TUNER... thereby shutting the signal down to the amplifier's remote turn on lead.
See the bottom comment of the tip AT THIS LINK. under NOTES:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 15, 2009 | Kenwood KDC-MP238 CD Player
No AM!
A possibility is that the antenna cable/plug is shorted. You can try verifying this with a continuity tester or simply unplug the antenna and stick a piece of insulated wire with the tip/end stripped into the antenna. Try the AM with the wire as the antenna. Just be carefully not go that far as the wire may reach the PCB/electronics.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Pioneer DEH-1000 CD Changer
How do we adjust our tv
You didn't mention anything about a cable box, VCR, etc. which might be connected. A snowy pic. means simply, inadequate signal is reaching the tuner, or the TV tuner itself is bad. If the first is so... check your cabling. If you have a VCR or DVD player hooked in between the cable box or outside antenna (whichever is the case), VCR (RF or ant.) out should go to the TV, VCR antenna (RF or ant.) input to the cable box. Also check the cable wire itself. If you look at the end of the cable, you should see a relatively thin center wire. This center conductor is what carries the signal. If it is missing, bent over, or too short to make contact with whatever it is connected to, you will have a very snowy pic. If you have a spare TV, connect it in place of your "new" TV, to narrow down the problem. Lastly, if all is well with hookup, cabling, etc. the TV might have a problem. Sometimes the tuner has a component defect, or the coaxial connector can be broken.
Sep 25, 2007 | Televison & Video
Pioneer DEH-1000 CD Changer Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
