Maxtor drive worked fine. then computer started to not start would start and power down immediately. I unhook maxtor drive and computer starts working again.?.. How and is it possible to get my data from the drive?
    Genius:
  • 3,587 Answers
Is that an external drive? then, you'll need to simply re install the drivers on your hard drive, and then install it like it's brand new...files should be ok
Posted on May 25, 2008
Maxtor 320 GB mini not working
If it shows up as a USB mass storage device it:-
1. Has power
2. It is connected to the computer via USB.
3.The correct software has been loaded for the hard drive.
The beep sound is probably an error message saying that the drive is not responding properly inside the case.
Hard drives Drives have been known to stick or not start up due to power cables or ribbon cables being dislodged. Try pushing these back into place.
If this is not the problem go to the Maxtor site (maxtor.com) and report the problem with the drive, not the USB which appears to functioning correctly.
Mar 07, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
How to format maxtor 80gb hard drive
Insert the drive into the bay and connect power and ribbon cable.
Go to Start > Control Panel > Administrative Tools >
Computer Management > Storage > Disk Management
Right click on the drive, click Mark Partition as Active then Format.
In this day and age, it's always best to format to NTFS file system.
Nov 06, 2009 | Maxtor Hard Drive
Maxtor 3200 personal storage will not load on my computer or any computer tried 2 other laptops - it was working but had to turn off desktop computer due to storm & then when computer was turned back...
Did you unplug the power supply for the computer and external drive seperately or simply turn off the computer? If the lights do not com on as expected for the Maxtor drive then the power supply for the drive may have been damaged. If the do it may just be an untimely failure in the drive. Did you shutdown the computer via windows or just "pull the plug" when it started storming? Fill me in on these details and I will help you narrow down the source of the problem. Chris
Jun 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 power indicator lights but computer won't recognize
ooooh, that sucks.
I assume you have tried unplugging it and plugging it back in?
Have you tried to see if it will work on a different computer?
I hop you had it all backed up.
If nobody else's suggestion beat mine...then I give you 2 options.
You have to take it apart (might have to break the shell, since most aren't designed to be user friendly), once you have the actual hard drive out of its housing, open up the side of your computer, and hook it up.
it will have to diferent connection points. One will be power (thats the plug that has (i believe) 4 pins in it...hook that up so your drive has power...the other plug is for data (read/write), its either a sata or ide (depending on how they (maxtor) made it). I assume you dont know what sata or ide is...just google pics it...once you see a picture...you'll know.
anywho, once its hooked up...start you computer back up (FYI, when you do this 'operation', shutdown your pc...and then unplug it)
once you have it all done and loaded back into windows, it should automatically detect it (give it a few minutes).
that scenerio I just laid out for you, is assuming its anything but a hard drive issue.
if it is indeed a hard drive issue....then apart from sending to to some VEEEERY expensive palce that could extract the data for you. theres only one more option. Put the hard drive in the freezer for several hours, then take it back out and hook it up to you computer, if it detects it...move fast, and start transfering all your files off it...cause now its living on borrowed time.
the reason this works **sometimes**, is because of the hard drives heat, its its platter actually expands over time a (very very very tiny bit), enough to mess it up, and when its chillin in your frezzer, the platters contract a little bit...making you able to get your data back...hopefully.
hope all goes well.
Mar 20, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Can't detect an external Hard drive (Maxtor 1TB)
im going to assume your on XP for these instructions. other wise you still need to do the same thing.
right click the my computer desktop or the start menu. go down to properties. open the hardware tab. open the device manager. Scroll down to it, remove the driver, just delete the whole entry. unplug the hard drive, then plug it in again. See if that works.
hope this will fixya....
Jan 05, 2009 | Maxtor Hard Drive
Maxtor external hard drive stopped working
How is it connected ? USB?
If you start w/o Maxtor connection is your PC starting correctly?
Is issue showing when you connect USB cable on working PC?
Jan 04, 2009 | Acer Extensa 4620 Notebook
My Maxtor mini III Want work at all
If you are running PC, go to Start -> Run -> type 'Services' (or go to Control Panel -> Administrative Tools -> then Services).
Finally scroll down to where it says Universal Plug and Play Device Host, and double click it. At the bottom, you'll see either an option to start or stop the device. If stopped, start it, and change it to automatic.
If that doesn't work, try using it with another comp. Does it open then? IF so, its your computer that is the problem here. If not, you have hardware failure.
Was there a reason why you got new anti-virus software. Did you have a virus before. If so, there might have been something that happened to it via a virus.
If this is the case, if you at least get it running some how, run a virus scan on the drive.
Do you have a warranty on the drive? Cause if worse comes to worse, you can just replace it.
Dec 09, 2008 | Maxtor OneTouch III Mini Edition 120GB...
The drive is dying. If it is still under warranty, call Maxtor for a replacement.
Dec 13, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor 3200 usb personal storage
Hi kieronr
maxtor 3200 usb personal storage drivers can be found at
driverupdate us .
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Oct 30, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
