Question about Techko SH52008 Shredder
Where can I get a repair manual for a Techko SH52008 Shredder?
  • Robert Kitaji Oct 04, 2010
    found out Techko does not provide parts. Unobtainium.
4 Suggested Answers
fellowesrep
  • 102 Answers
SOURCE: Techko SH2106PA
your blades have either become dull or have spread due to a jam or a broken mount on cutter if your in warranty contact manufacturer if not time to buy a new machine.
Posted on Mar 02, 2008
frcs68
  • 1605 Answers
SOURCE: Shredder runs continuosly
unplug the shredder and get aflash light look into the cutting slot.
there is micro switch in the slot.
must likely the switch is stucked, and not flipping back out.
try to use something thin clean off some of the glue (yes glue!) on and around the switch.
make sure the switch is free to move.
Posted on Nov 28, 2008
SOURCE: Techko shredder model #SH4205PD.
The micro switch referred to is to triggers from the presence of a piece of paper in the slot when on 'Automatic'. If this is stuck in the closed position it will easily be verified by placing a piece of paper in the accepting slot on the top of the machine. If it turns on it is stuck in the closed position. These shredders obviously get quite dirty and may simply need cleaning. Be Very Careful when working on any shredder! Also. the slide switch while basic in design has a number of wires on 8 poles and could also be the problem. As well if you these machines are protected by a thermal cut-off circuit if you overworked it give it sufficient time to cool down and reset. These are the most probably things to look at however, more in depth Dx may be necessary.
Good luck.
Posted on Sep 12, 2012
Does this shredder activate when it senses paper being fed?
in the space where the paper goes to be shredded is a very small plastic level that is pushed sideways when the paper is put in
this lever is between two cutter blades and is easily jammed in the on position from paper bits
remover any paper around the center of the shredder that is blocking up the cutters
Jan 20, 2016 | Techko Office Equipment & Supplies
How do I unjam it?
Sometimes the only effective way to unjam a shredder is to turn it upside down (with power disconnected) and pick out the jamming material bit by bit. It is a tedious, messy job.
Aug 12, 2015 | Techko SH1524CP Shredder
How to open
More information would be helpful. If you mean "open" the top portion where the motor is, you can find the answer you need by going on YOUTUBE and just type in what you are looking for.
Jul 12, 2014 | Techko SH52008 Shredder
Shredder won't power up
hI
Did you check your power connection well all the fuses?What brand of machine do you have?
Feb 06, 2014 | Techko SH2106PV Shredder
No longer cuts through paper
This is the problem I have the paper no longer cuts all the way. Some parts just seem marked with out cutting what do I do?
Apr 17, 2009 | Techko 6-Sheet Straight-Cut Shredder
New gear drive cog needed for c505pz shredder please
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Mar 19, 2009 | Techko SH2106PA Shredder
Nov 21, 2008 | Office Equipment & Supplies
Techko SH2106PA
Dec 14, 2007 | Techko SH2106PA Shredder
Techko SH52008 Shredder Logo
76 people viewed this question
Top Techko Office Equipment & Supplies Experts
Adorjani Laszlo
casper muchato
Level 1 Expert
Tom Chichester
Are you a Techko Office Equipment and Supply Expert? Answer questions, earn points and help others
