Question about Hardware & Accessories
Have digital timer made by MDL Corp.; model #301-0005. need to reset clock and on/off times. don't have manual.
  • Kurt T. aydin Nov 24, 2012
    thanks so much - I have the same problem
  • 3,740 Answers
The manual can be found here:
http://www.themustardseedinc.com/nightlighting/301-0005%20Digital%20Time%20Switch.pdf
Everything but the display picture is listed below.
Kelly
301-0005 DIGITAL TIME SWITCH
Combined Daily / Weekly Electronic Timer.
Operating instructions. Please read before use.
Features:
• Up to 12 on off switches a day / 84 on off switches a week.
• Option to program individual days or 8 different weekday groups.
• Minimum switching period one minute.
• Summer time / Winter timer changeover.
• Easy to read LCD display.
• Random automatic On / Off security feature.
• Manual override button.
• Battery back up: Alkaline battery 1.5v "AA" size.
Setting the time.
1. Press and hold the CLOCK key. With this key held pressed, the DAY key can be used to select the correct day, the Hours key to select the correct hour and MIN. key to select the correct minutes. When the MIN. key is released the time will be set with the seconds starting from 0. Either holding down or repeatedly pressing the appropriate button can advance the days, hours and minutes. Please take note of AM or PM being indicated in the LCD display and adjust as required.
Programming of switching times.
Your Auto Time switch has the capacity for 12 on/off switches. By using the blocks of days available you can save program capacity.
The blocks of days are:
Mon, Tues, Wed, Thurs, Fri, Sat, Sun
Individual days of the week
Mon, Wed, Fri
Tues, Thurs, Sat
Mon, Tues, Wed
Thurs, Fri, Sat
2. For each On time and each Off time the Day, HOURS and MIN. must be set.
3. Pres the PROG key once to set the first on time-you will see "ON" and the number "1" appear on the left of the LCD display. This indicates that you can now enter the first On time. Press the DAY button to choose the required day or block of days, and then set the hour and minutes using the HOURS and MIN buttons.
4. When you have completed setting the required On time press the PROG. Button to validate the entry and move onto the first off time-you will see "Off' and the number "1" appear on the left of the LCD display. This indicates that you can
now enter the first off time by using the Day, HOURS AND MIN. buttons as above. Pres the PROG. Button to validate this entry.
5. Repeat for the remaining 11 on/off settings as required.
6. When you have set the required On Off settings, press the CLOCK button to return the display to the clock. The timer will now be ready to operate.
NB. You can check the settings you have programmed by pressing the PROG. Button repeatedly-each setting will appear on the screen.
Manual Override Switch.
You can choose permanent ON, Permanent OFF and Auto mode by switching the Manual Switch. The program settings will only work in Auto mode.
With this option selected the timer will switch On and Off in a random pattern based on the set program with a time variation of 2-32 minutes added to the set switch times. For example, if timer should be On 5:30 to11:15,the program adds between 2-32 minutes to 5:30. Likewise it adds between 2-32 minutes to 11:15. this is ideal for use with a light, switching it On and Off automatically when you are out to make your home look occupied but still not exactly the same time every day.
Switchover summertime / wintertime / summertime, time zone change.
To change from winter time to summer time press the HOURS and MIN. buttons simultaneously. The clock will be set forward one hour and "S" will appear on the display. Repeat the same procedure in order to return to winter time.
NB. If you purchase this unit during the summer, when setting the clock set the time for one hour less than the correct time and then when the unit is in the auto mode press the HOURS and MIN. keys simultaneously. The unit will then adjust to the correct "summer" time and the "S" will appear on the LCD.
Reset Button.
To reset the unit, both the time and programmed On / Off settings, press the Reset button.
Posted on Sep 29, 2010
  • Richard Schommer
    Richard Schommer Jan 09, 2015
    How does this digital timer work with a photoelectronic switch plugged into it ? Tork model 2021
I'm trying to cut off the timer on a sony t.v.RM-Y909 so I can turn my t.v. on with the remote control.
The RM-Y909 works for the KP46WT500, among other TVs. For the KP46WT500: to reset Timer 1 or Timer 2, you need to access the timer sub-menu. With the TV on, press Menu. Use the Joystick on the remote to select the Timer icon (looks like a clock) then press the center of the joystick (with the + with a circle at the center symbol). Use the joystick to select the timer you want to reset and then press Reset (on the left side at the bottom of the remote). Alternatively, you can just turn off the timer. The TV will remember the settings. Press Menu to exit the menus.
Sony has the manual on their product support page in the manuals tab: https://esupport.sony.com/US/p/model-home.pl?mdl=KP46WT500 . The direct link is https://docs.sony.com/release/KP46WT500.PDF . The Timer menu section is on page 57. I hope this helps.
Aug 31, 2015 | Sony Televison & Video
How do I set the clock? The included instructions for setting the clock do not work. I can set all the programmed on & off times, days of week, etc., everything except the friggin' clock. The cl
Give us the model number so we can see what you're talking about. Tell us what link you have tried, and how the instructions seem to be different.
Display showing no-op is sometimes associated with defective timer, bad battery. Resetting timer will clear memories and restore functionality in some cases.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
Attach photo of timer, or description of timer.
Add if this is new timer or if timer worked before, and what load the timer controls
Do you have correct instructions for timer ?... scan the manual into .pdf format. and then post the .pdf manual on your website .... then post link here to assist other folks with same problem.
Gene
Water Heater Timers Save Money
Dec 11, 2014 | Hardware & Accessories
I have a 7-day timer model em0101 and can't set it
That timer is not identified:
Copy following link to see variety of timers that might match your timer, and then download same-similar manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Jun 15, 2012 | Timex Hardware & Accessories
MDL Corp - Manual Timer 301-0004 (Outdoor Lighting)
Timer brand and model are not identified.
Some timers are rated for incandescent light bulbs, while other timers are rated for CFL incandescent and all types of loads.
Open following links to help identify in-wall timer:
http://waterheatertimer.org/Programmable.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
May 28, 2012 | Home
How do I reset the Polder Clock Timer - the narrow white one which has clock, count up and timer?
Timer is not identified for certain
Polder timer manuals appear on following link:
http://www.polder.com/productinfo.html
Typical manual says to hold down clock button for 3 seconds until display disappears.
Another part of manual says to press start/stop then clear to reset timer to 0:00:00
Another part of manual says to press clear to reset timer back to 00:00:00
http://polder.com.p2.hostingprod.com/images/instructions/898_instructions.pdf
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 27, 2011 | Polder Triple Digital Timer Model 891-90
I cannot find my manual for the Sony Cyber Shot DSC-H2 and I am trying to figure out how to set the self timer to take a family holiday photo of us without having someone take the picture. Does...
You can download the manual and more from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCH2&LOC=3
Press cursor-down on the multiselector (marked with a one-handed clock) to cycle through the different self-timer modes. Start the self-timer by pressing the shutter release button.
Dec 09, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
http://waterheatertimer.org/pdf/Woods-59203.pdf
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Release clock button
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
Oct 17, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
Timer needs to be reset.... comes on during the day.....
The manual is located here:
http://www.themustardseedinc.com/nightlighting/301-0005 Digital Time Switch.pdf
Thanks for choosing FixYa
Kelly
Apr 21, 2009 | Hardware & Accessories
Hardware & Accessories Logo
1,591 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
