Depth gauge - model ID-C1012EXBD How to reset zero when extention have been fitted
Temperature and depth reading is bouncing around all over. Is that something I can fix???
Popular Mechanics - Jan 1961 - Page 139 - Google Books Result
https://books.google.com/books?id=XNsDAAAAMBAJ
Vol. 115, No. 1 - ‎Magazine
Right, plates of full depth and weight ... Loose hold-downs - bouncing arounddamages a battery several ways ... Excessive loads - using the starter to move thecar should be only a ... ask for a temperature-corrected hydrometer reading, which should be 1.260 specific gravity. ... All this is dependent on the individual car.
Ask the Experts - USA Today
temp gauge bouncing around before going to center? ' Yahoo Answershttps://answers.yahoo.com/question/index?qid...Sep 28, 2013 - I called my mom and we switched cars and she didn't see anything ... Best Answer: If the temp gauge is literally "bouncing around" this is more ...Why is my temperature gauge jumping?Jan 1, 2013Temperature gauge bouncing.?Dec 18, 2008What does it mean, when my coolant temp needle jumps up and ...Oct 3, 2008My car temperature gauge keeps bouncing around from cool to red ...Dec 12, 2006More results from answers.yahoo.comTemperature Gauge Jumping Around an
Jan 23, 2016 | Cars & Trucks
I have a i50 tri the depth has a 15 sec delay on it is this noral
Hi
From your user manual (page 64)
Setting the response delay for depth readings
From the User Calibration Menu Access page:
1. Press the Depth button until the Depth Response page is displayed (3 presses from the User Calibration Menu Access page).
2. Use the Trip and Reset buttons to adjust the depth response to the required level.
The default level is 12. The levels available are 1 to15 with level 1 being the slowest update rate and level 15 the quickest.
Manual is here if you need it:
http://www.raymarine.com/view/?id=5125&collectionid=118&col=10576
Hope this helps you out.
-Steve
Sep 29, 2014 | Boating
How to reset depth micrometers , any style , easiest method for Mitutoyo line
The nut on the end of each rod is for calibrations. On a clean flat surface check your reading at "0"and see if adjustment is needed either left or right on the nut for getting before zero or after zero readings. Adjust the nut as little as possible and re check for zero multiple times because the nut is sensitive. hope this helps.
Jun 29, 2011 | Mitutoyo Depth Micrometer 0-6"
Ran ok at 70mph but the gauges all went to zero for approx 10 sec
If it happens again, smack the top of the dash above the gauges with your hand. If the gauges come back on then remove the gauges and clean the plug contacts. This usually will restore proper operation. Some people actually put a slight bend in connectors to get a tighter fit...you can do that but don't get radical or it won't go back together.
Nov 19, 2009 | 1999 Jeep Wrangler
How can i find stainless steel panels for the front of my sub zero model 590
We are factory authorized Sub Zero parts and service. Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 Am until 9 PM CST for all your Sub Zero parts and supplies.
We look forward to hearing from you. Thanks, Ella
Nov 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
My depth finder flashes 00.0 I can not get it to work
The shallow water sensitivity adjustment is set too far to an extreem. Center the adjustment, then recalibrate at the dock.
May 24, 2009 | Uniden Qt206 Thru Hull, Digital Depth...
How and why scuba gauges give a diver critical information while scuba diving?
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
Dec 01, 2008 | Aeris Max Depth Analog 2 Gauge Console
Scuba Gauges what do I need them for?
"A diver relies on scuba gauges to know three things: 1.-Depth 2.-Air Consumption 3.-Time Depth and Time are vital for nitrogen and air management. A scuba diver needs to know how deep he has been and for how long in order to judge the necessity and length of decompression stops and to calculate residual nitrogen for repetitive dives. The time of a dive is easily tracked using a scuba diving watch and the depth is tracked using a depth gauge. "
Scuba Gauges importance
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
