Question about KitchenAid KWCU265HSS Kitchen Hood
For the last few months my vent hood's motor has been making a lot of noise whenever it was in operation (making a squeeking sound like it needed to be oiled). Then it simply stopped working. Do I need a new motor or is it possible to fix it? it's only five years old. (model number kwcu265hss) Thanks!
  • KitchenAid Master
  • 43,501 Answers
It is possible that if you can get the motor out of there and get some WD-40 worked into the bearings you can get it running again...
turn it so the shaft is pointing up and then spray the WD-40 right on the shaft and let it run down and into the bearing...
once you get the shaft spinning more freely then place a few drops of light motor oil or sewing machine oil on the shaft and let it run into the bearing before turning the motor from the shaft up position and reinstalling...
heatman101
Posted on Oct 02, 2010
A/C Heater Blower Motor for 2010 Nissan Altima, was making a noise for a few weeks and then just stopped blowing.
sounds like a mouse attack to me. mice get into the heater vents and blower motor cage and make nests. those can throw your blower motor out of balance, thus resulting in the noise and then the motor just gets jammed and stops operation. but it could be just the blower motor failure it self. have it checked.
Jun 28, 2013 | 2010 Nissan Altima 2.5
KitchenAid KHTU160KSS Kitchen Hood makes noise
Remove the fan and motor assembly from the hood (the fan motor will plug into the hood housing) and using an electrical motor cleaner (such as CRC electrical motor cleaner available from your local auto parts store) wash the motor and fan as completely as possible, lubricate the end bearings (sparingly) with a very light oil such as sewing machine oil, gun oil or as a last resort 3 in 1 oil. Hope this helps.
Dec 14, 2011 | KitchenAid KHTU160KSS Kitchen Hood
A squeeking type sound coming from the serpentine
Noise could be the result of a dried out belt, a belt that needs adjustment or any one of the pulleys driven by the belt. The oil pump has nothing to do with the belt. Inspect it and try tightening it up a bit. If that does not help, remove the belt and check all the pulleys for noise and rough turning, replace the belt and re-tighten.
May 03, 2010 | 2001 Dodge Ram 1500 Truck 2WD
Car makes a squeeking noise when driving then it killed on me today when the squeeking was very loud.
check for a siezed pully under the hood remove the belt and check to see all pullys spin free with no noise also check the AC clutch make sure it free spins.
Dec 02, 2009 | 2002 Ford Mustang
2004 Saturn Vue V6 Honda motor
ld still be the ball joints. yhe sound travels. place your hand on the ball joint and have someone bounce the car you can almost always fill the noise when you hear it.
Jun 11, 2009 | 2004 Saturn VUE
Suspension squeeking
My ford had the same probelms. To get rid of the problem replace your shocks. They are what is making noise. Easy fix by yourself. Or sears has a good deal on shocks and installiations right now
Feb 12, 2009 | 2007 Nissan Xterra Off Road
Refridgerator Not Cooling
If top is compleatly warm it is probley the fan motor, lot of failures on them. Replacement one will be a different looking motor. Verify motor is not turning, located in the back of the freezer in the top middle, behind small grill. Will see fan blade pointed up, should run whenever compressor is on.
Aug 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Open Questions:
Fan not working The fan on the hood stopped working (i.e., nothing happens when I turn it on). From this wiring diagram: http://www.fixya.com/support/p106093-kitchenaid_kwcu265hss_kitchen_hood/manual-13670/page-9, you can see that the hood has two circuit boards. One for slided switches and speed control (Part Number: AP3133509 made by WHIRLPOOL), and one for motor control (Part Number: AP3105889 made by WHIRLPOOL ). My best guess was that the motor control board went bad, so I ordered a new motor control board to replace it. You will see five wires coming out of the speed control portion of the first board. The white wire goes directly to the fan motor, but the other four (blue, orange, black, and black), go to the motor-control board which also has four wires of the same colors. OK. Blue to blue, orange to orange. No problem. But what about the two black wires coming from the speed controller and going to the two black wires on the motor-control board? Does it matter how these are connected? I figured if it mattered, they would also be color coded, so I just connected black to black, black to black (random order). When I turned on the fan, it blew out my new motor-control board. I have a new motor-control board. I was going to try reversing the two black wire connections, but don't want to blow out another board. So, my question is, do you think it is important to match a specific black wire on the motor-control board to a specific black wire coming from the speed controller? It seems strange to me that it would work this way, as these wires snake around through the hood, and it virtually impossible to tell which is which when when they reach the motor-control board. I don't know how they would be been matched during original assembly. But I can't think of any other problem. By the way, I was able to by-pass the motor-control board and run the fan directly, so I don't think the problem is with the fan motor. I have also replaced the control board used for the slider switches and speed control, so the problem is not there either. Thought welcome. Thanks. jp
Oct 17, 2008 | KitchenAid KWCU265HSS Kitchen Hood
KitchenAid KWCU265HSS Kitchen Hood Logo
213 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
