Question about Acer AL1715 17" LCD Monitor
AL1715 flat screen pc.
Hi, my screen has a pink happening with it, any idea whats happening. thanku
donna
    Sergeant:
  • 336 Answers
When your screen starts to act funny it is most likely a bad part inside of the monitor. Replacement parts are cheap but because of all of the capacitors inside the screen it will cost much more money to repair.
Have you done diagnostics's on the monitor? If not I can see what I can do to help you find the problem. I will give you detailed instructions on how to run diagnostics on your screen if you need.
All The Best,
RCF
Posted on May 31, 2008
  • 472 Answers
It could be one of 2 things.
#1 A broken wire in the cable between the computer and monitor. You will be ale to test this by moving the cable in a circular motion close to the computer and then close to the monitor to see if ti corrects the problem.
#2 A failing CCFL (the light tubes inside the monitor). If this is the case then it's not normally cost effective to have repaired. The part is not expensive, but the repair cost can be high due to the high risk nature of the repair. One slip while doing this operation can cause a complete failure of the physical LCD panel. The driver tabs that connect the panel to the controller baord are extremely fragile.
Posted on May 27, 2008
My acer al1715 has a pink tint. It started
This is a low-end monitor and the image processor is failing. You will require a replacement but since the monitor is low-cost, it is cheaper to simply by a new one.
Jan 20, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Screen goes pink periodically
check video cable connection....sounds like a bad monitor..also try different monitor .
Dec 12, 2009 | Acer AL1715 17" LCD Monitor
Auto configation
when do you get this dialog try to run self test on the monitor if same thing happens then change the settng of your monitor to default (factory setting)
Jun 15, 2009 | Computers & Internet
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
AL1715 problem with colors
1 year warranty on parts, unfortunately the capacitors on these boards go bad and they can be replaced fairly easy if you can solder.
given your issues I think that there are some bad caps (blown) and they could be replaced very cheaply say under 100 usd + shipping for both if I do it, or for less than 30 usd if you do it.
let me know what you want to do
Sep 01, 2008 | Acer AL1715 17" LCD Monitor
PS3 BD payback causes a pink screen
Dear customer
sir,,i think ur avr receiver is not working ..tty to change that
thanku
Jul 16, 2008 | Sony Playstation 3 (PS3) Console
Hi there, thanku for this site.. for some reason some of the keys on my acer aspire 5100 series(model # BL51) type something other than what i type... mostly in the middle of the keyboard.. I remember one...
HEllo Again,
Thank you... Its my pleasure...
Kindly give a feed back to Improve my statistics by Rating My advice and to see If it was helpful for you...
Thanks and Regards
Mar 28, 2008 | Computers & Internet
Pink monitor
When you got the new monitor, did you also get a new cable? Most likely the issue is not the monitor but either a bent pin on the cable connector or a bad wire within the cable. Try using a cable from another monitor or borrow a friends to test, before you buy a new one.
Mar 10, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
MY COMPUTER HAS BEEN LOCKED
Hit the power button till it shuts down. Let me know what happens when you turn it back on.
Jan 02, 2008 | Computers & Internet
Acer AL1715 17" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
