Question about Whirlpool Dryers
I have a Whirlpool electric dryer several years old (front loader) that just suddenly stopped working - the left side knob that you push to start stopped turning on the dryer. I have reset the breaker at the box to no avail, have checked the plugs and have taken off the back to expose the switch behind the knob, a white plug with the number 3398095 (FSP). It looks OK, not blown, but could this be the problem? If so where can I purchase one before calling a repairman to come out? Thanks!
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Sep 30, 2010
Whirlpool electric dryer will not start when start knob is pushed
First check beaker flip it off than back on next check the door switch if tab missing or loose it should spring back when pressed next the dryer may have over heated the thermal fuse may have blown
Nov 03, 2015 | Whirlpool LER4634J Electric Dryer
3 years old, totally dead dryer
remove the back panel look on the side of the heating element look for a small red button on the thermal fuse push it in.
Also look on the left side by the belt and motor you should see a black piece of plastic with small springs on it push it to the right to reset it if this has tripped,this is a saftey kill switch that gets activated by the drum belt if there if a sudden problem with the belt tension
Mar 15, 2010 | Bosch Nexxt 500 Dryer
Front loader gas dryer suddenly stopped heating
The dryer may have a clogged or kinked vent line.
This will stop the heating.
remove the vent line form the rear of the dryer and see if it is hotter.
if so the vent line needs to be cleaned or replaced
Apr 03, 2009 | Dryers
Dryer starts to run on its own
Some dryers have a touch up cycle that runs automatically to keep clothes from wrinkling if they are left in the dryer.
Some touch up cycles are selectable. Some are automatic.
Mar 07, 2009 | Whirlpool GEW9250 Electric Dryer
I have a whirlpool duet washer and dryer the dryer lights all come on but I get a beeping sound and dryer will not start
try to unplug the dryer for 5-10 minutes this should reset the board. if not take off the bottom panel and test the resistance of the thermistor ( the tech sheet is in the bottom there or up top)
Dec 09, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Oct 13, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryer only starts sporadically
your headed in the right direction. there are contacts inside the timer that have gone bad. the timer is in the console ofcourse. its not hard to replace and replacing it will solve your problem
Nov 25, 2007 | Whirlpool LEB6300 Electric Dryer
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Mar 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
73 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
