Question about Pioneer DEH-1000 CD Changer
No AM! hey mate, just installed a pioneer DEH-1950 cd tuner into an holden astra, everything is working except for AM frequency, im a mechanic and its done my head in. FM and cd's are working just no AM. wat ur thoughts??
  • richos May 25, 2008
    ohk thanks for that, do u mean the antenna plug may be shorting to body of cd tuner?? and if so shouldnt that be affecting FM frequency?
    when i put it on AM i can pick up stations extremely faintly.
    wats your thoughts?
    Brigadier General:
  • 6,966 Answers
A possibility is that the antenna cable/plug is shorted. You can try verifying this with a continuity tester or simply unplug the antenna and stick a piece of insulated wire with the tip/end stripped into the antenna. Try the AM with the wire as the antenna. Just be carefully not go that far as the wire may reach the PCB/electronics.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 25, 2008
  • Louie  Role
    Louie Role May 25, 2008
    Hi again richos,
    The outside area of the antenna plug would definitely touch the body of
    the CD/Tuner as it is the ground where the shielding of the cable is
    soldered to. I was referring to the central point where the active wire
    is soldered to and is connected to the exposed antenna element.
    Another possibility to consider is the orientation/location of the vehicle/antenna (though unlikely).
    As to the FM, it would still work (even if shorted) since it operates
    on MHz (unlike AM in KHz). Some antennas for FM (exclusively) even have
    a balun (coil) matching which is shorted when tested for continuity.
    Have you tried the insulated wire?
No audio on Pioneer DEH-1100MP
I'm having the same problem worked for a couple of days then just stopped playing music
Jul 17, 2010 | Pioneer DEH-1100 CD Player
Pioneer deh p3100ub shuts off when i touch deck
sounds like the faceplate is not seated right or has dirty connections but it is in your detachable face plate. your still under warenty.
May 24, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
I have a honda im trying to hard wire it directley with the pioneer harness everything is connected right except there is no wire for my illumination wire to connect to. also im getting no power to th
you do not need to connect the illumination wire that is to dim the radio when the lights are turned on. make sure you have +12v on both the red and yellow wire and ground to the black wire. the yellow should be unswitched and the red should be a switched source.
May 20, 2009 | Pioneer DEH-1100 CD Player
Pioneer deh-6400 tuner has no audiobut cd plays ok
Did you also use an antena adapter? If not you may need one. Original in the vehicle is small and can pop out from the radio.
May 18, 2009 | Pioneer DEH-P6400 CD Player
Pioneer DEH 1950's favorites/booksmarks/number inputs reset
hi mate,
the cd player consists of 3 types of wires, 1 for negative, 1 for memory- the yellowcolor wire, 1 positive-the red color wire. you must connect the memory wire(yellow) directly to the car battery so that the battery constantly feeds electric current to the player to store your bookmarks or whatever you program it. the red wire must be connected to the ignition barrel( which means your key starter). the negative(black) must be connected to the negative terminal of battery.
Jan 09, 2009 | Pioneer DEH-P430 CD Player
Pioneer DEH P6000 screen reads "tuner er"
try disconecting your battery while its on then reconnect
Jan 01, 2009 | Pioneer DEH-P7000BT Car CD/ MP3 Player
Odd frequency
Hey, all you have to do is to turn off your radio and press on the audio botton until you can adjust your clock, then press again until you see "FM 100" on the display, now push the ">" botton to change it to "FM 50" and finaly another long press on the audio to wrap up.. and it's done.
Feb 15, 2006 | Pioneer DEH-245 CD Changer
Pioneer DEH-1000 CD Changer Logo
123 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
