Dell E153FP 15" LCD Monitor Logo
Posted on Sep 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor does not light up. small white -like hyphen- in upper left corner of monitor
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Sep 29, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368760
Points
33650
Your monitor is working otherwise you will not see the cursor on the screen, you are having computer problem, not the monitor problem. You can verify that by using this monitor with other PC or try another monitor with this PC.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
A small blinking light on the left upper corner of panel after a power outage and I can't do any command. The interior lights don't even come on when opening door. I already reset the breaker
Unplug the microwave oven for 10 minutes in a attempt to reset the microprocessor ic, press and hold the start button for the same time and release. Now plug everything back in hopes it will restart, if no change! the keypad control board will need to be replaced along with other unknown parts, due to the nature of damage far cheaper to replace.
When booting up, the monitor status splash shows up. Then it goes into a black screen with some small white boxes in upper left-hand corner. It takes forever to display the log-in screen, probably more...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Please leave a vote if you like my answer
3helpful
2answers
HP LaserJet M4345 - The printer display is mangled, the touch screen does not respond properly to commands. Is there a way to reset it?
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
I have acer aspire 3000. My screen goes blank with flashing hyphen in left upper corner after bios screen. I cannot reboot because it goes to blank screen.
It means that the HDD is not getting detected on the computer.
Try resetting BIOS.
If that doesnt help, check whether your HDD is bad.
1helpful
Computer monitor went black with small white blinking light on the upper far left corner....help?
your monitor appears to be working. Do you see any kind of text after rebooting? Was a CD left in the drive?
Unplug the monitor data cable from the computer, it should nag you about NO SIGNAL
Small black rectangle in upper left corner of toshiba 52hm85 dlp
Sounds like it is closed captioning coming up. I would go in and verify both your TV's and the Cable/Satellites closed captioning is off.
What is the best setting on adell 24
The issue is relative to the native resolution of the monitor. in most 24" monitors the resolution is 1920 x 1200. When you get an application that is shown in the upper left corner of the screen, it is most likely set in a page frame of 800 x 600 or 1024 x 768. Also many web pages will display with large amounts of white space on one or both sides.
This you can do to help.
Set the DPI setting in display properties to 120 will help some making small type more readable.
Pages that are in Internet Explorer can be zoomed to appear larger zoom feature in bottom right corner of IE window (or CTRL & + and CTRL & - key combinations)
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
