Question about Dell Latitude C640 Notebook
Laptop keeps shutting down, both fans not working
Hello, I have a Dell Latitude C640 that has worked perfectly for a very long time. But all of a sudden one day when I turned it on it kept shutting off after just a few seconds. If I try to turn it on with only the AC adapter connected (no battery) it usually requires that I push the start button a few times before it will turn on, but then it will shut down after a few seconds. If I try to turn it on with just the battery connected (no AC adapter) it will turn on the first time I push the start button, but then it shuts down after a few seconds. After a few times of trying either of these methods to start the laptop it won't start at all and I will need to wait a while before trying again. Regardless of which way I get it to start, I notice that both the CPU fan and case fan are not spinning at all. What would be common to both the CPU fan and the case fan not spinning at all? Is it possible the laptop is overheating in just a few seconds, and this is what is causing it to shut down?
Thank you!
  • 1 more comment
  • nerdneedafix May 25, 2008
    No it is not under warranty. So I have nothing to lose by opening it up and trying to fix it myself. What does uP mean?
    Thank you for such a quick reply.
    If the microprocessor was bad I don't think it would boot into windows at all, even for a short time. No?
    I have done a lot of repair work on desktops, but have never taken a laptop apart. Dell has instructions and schematics on its web site for disassembly of the Latitude C640. I have nothing to lose and maybe I'll get lucky and find something I can fix; like a broken solder joint or something.
  • dan-0-soar Jun 06, 2008
    I have the same problem. I have not yet opened the case but note that the bottom case fan is not spinning. Is there something that I can do? Does this have anything to do with the CMOS battery? Bad connection? What?
    dan-0-soar
    Genius:
  • 3,587 Answers
Sounds like you have a bad motherboard, or uP...is this under warranty, by chance?
Posted on May 25, 2008
  • Patrick Michaels
    Patrick Michaels May 25, 2008
    uP..microprocessor
    you ever done this before? It takes me almost 45 minutes to do this, and that's with 20 years of training..it's like major surgery
  • Patrick Michaels
    well..uP can get hot, and slow down..it's not a failure positive device, unless it's hit by lightning.
    i work on Dells all the time..component troubleshooting is problematic, for a variety of reasons
My dell latitude c510/c610 failing
Sounds like the fan may be failing and need replacement. On a system that age, it is debatable whether it is worth fixing.
You can boot to he resource cd and run fan diags is you want to try and confirm
Fans can be found on EBay
May 26, 2010 | Dell Latitude C640 Intel Pentium 4-M...
Dell latitude c640
Hi
Both Dell Part numbers 18THT and 5W299 are 8X DVD-ROM Drive Modules. DPN 18THT is compatible with Latitude C series and DPN 5W299 is compatible with Latitude D series. The two drives have different and incompatible connectors.
Your Latitude C640 is a C Series Latitude. You can therefore not use DPN 5W299.
If you need a DVD drive module, get DPN 18THT or an alternative Latitude C series drive.
Mike
Apr 25, 2008 | Dell Latitude C640 Notebook
Dell c640 audio problems
i installed windows xp service pack 3 in dell c640 latitude laptop after which the multimedia audio controller driver is not installed.
Apr 23, 2008 | Dell Latitude C640 Notebook
Power/battery problem
just log on to support.dell.com
click on drivers and download
punchin your system's servica tag
download BIOS updates
but it will only be done if ac adapter and battery are both connected if its not
than it could be an issue with the systemboard and will be replaced if you live in US call 1-800-624-9896(DELL)
Apr 18, 2008 | Dell Latitude P4 C640 Business Laptop...
Dell c640 overheat
There would be no way to know if that is the case without opening the machine. I suggest taking it to a certified
laptop repair technician near you ( a Dell Store if under warranty ), and explaining the issue to them. I have not seen
this happen myself ( the heatsink popping off ) but that's not to say it can't happen. I suggest having the laptop
looked at sooner than later, as each time you turn it on and it overheats it reduces the life expectancy of your
unit.
Feb 24, 2008 | Dell Latitude C640 Notebook
Dell Latitude C640 Laptop
get to the main board of ur system there is a jumper near the battery .
change its position while power is off and get it back to its previous position. this way u will reset cmos to default.
if the computer starts hit delete to enter setup and load system defaults.save changes then exit.
ps: defected processor could be the cause
Nov 14, 2007 | Dell Latitude C640 Notebook
Dell Latitude C640 Notebook Logo
529 people viewed this question
Alun Cox
