Question about Bushnell NorthStar 78-8830 (525 x 76mm) Telescope
Cannot get an image - Bushnell NorthStar 78-8830 (525 x 76mm) Telescope
  • 3,186 Answers
I answered your question in a previous post.
Posted on Sep 29, 2010
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
Deleted images from digital camera can be restored but after deleting images if we have clicked images ,is there is any way to restore that images which we have deleted????
If you have deleted the images then the space that was occupied by these images is freed for the camera to place images into the freed areas.
It is highly unlike you can recover these deleted images as they would be over written by the new images.
May 12, 2012 | Sony Cameras
How do i change my picture size
hi
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. 1
jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.1-800X800.jpg'); }); Open Microsoft Paint. Paint is usually found under "Start," "Programs" and "Accessories."
  1. 2
jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.2-800X800.jpg'); }); Click on the "Image" menu, and choose "Attributes." This will open the "Attributes" box.
  1. 3
jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.3-800X800.jpg'); }); Choose which "Units" you would like to resize your image in. The options are "Inches, "Centimeters" and "Pixels."
  1. 4
jQuery(document).ready(function(){ jQuery('#jsArticleStep4 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.4-800X800.jpg'); }); Enter the "Width" you would like the image to be.
  1. 5
jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.5-800X800.jpg'); }); Enter the "Height" you would like the image to be.
  1. 6
jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.6-800X800.jpg'); }); Click "OK." Your image should now be the appropriate size.
Aug 14, 2010 | Lexmark X2500 All-In-One Printer
How do you install quicktime from a cd-rom
Installation
If you already have QuickTime installed, then we recommend to uninstall it first. After the uninstallation you should reboot your computer.
Now run the installer (QuickTimeInstaller.exe)
Click on the next button on the first page on the installation wizard.
Accept the license agreement.
Now you will be on the Destination Folder page. Uncheck the box for Automatic check for updates. You don't need that.
Click on the Install button. The installation will now begin.
Click on the Configure File & MIME Types button that is shown on the last page of the installation wizard. If you don't see the button, then don't worry, the file and MIME types can also be configured in the QuickTime control panel (see step 3).
File types:
At the bottom, uncheck the box in front of Notify me if other applications modify these associations.
Uncheck everything except these:
* Video - QuickTime Movie
* Miscellaneous - QuickTime HTML
Optionally you can also safely enable these:
* Audio - Sound Designer II
* Audio - GSM audio
* Audio - AMR audio
* Audio - CAF audio
* MPEG - 3GPP media
* MPEG - 3GPP2 media
* MPEG - AMC media
* MPEG - AAC audio
* MPEG - AAC audio (protected)
* MPEG - AAC audio book
* MPEG - Video (protected)
* images - MacPaint image
* images - PICT image
* images - QuickTime image
* images - SGI image
* images - TGA image
* images - JPEG2000 image
MIME Types:
* Streaming - SDP stream descriptor
* Streaming - RTSP stream descriptor
* Audio - WAVE audio
* Audio - MIDI
* Audio - AMR audio
* Video - AutoDesk Animator
* Audio - AIFF audio
* Audio - uLaw/AU audio
* Audio - QualCOMM PureVoice audio
* Audio - GSM audio
* Audio - CAF audio
* MPEG - 3GPP media
* MPEG - SD video
* MPEG - AMC media
Click on the Finish button.
Mar 12, 2010 | Apple QuickTime
How do I create a form field in adobe acrobat pro cs4 that will accept a photo?
Form fields will not accept images. The only way you can add an image is in a pdf that is already created. You have to use the "Paste Clipboard Image as a Stamp".
This is from the Acrobat Help file.
Here are the steps:
You can use the Paste Clipboard Image As Stamp tool to add images to a PDF. You can copy most image formats from drawing and image-editing applications, such as Adobe Photoshop and Adobe Illustrator. If you want to add the image to PDFs repeatedly, create a custom stamp of the image.
Note: The Paste Clipboard Image As Stamp tool isn’t available until you copy an image.
  1. Copy an image by doing one of the following:
    • In Acrobat, choose Tools > Select & Zoom > Snapshot Tool a_snapshot_sm_n.png, and select an image from a PDF.
    • In another application, select an image and choose Edit > Copy.
  2. Open a PDF.
  3. Choose Tools > Comment & Markup > Stamps > Paste Clipboard Image As Stamp Tool.
  4. Click in the PDF where you want the image to appear.
  5. Do any of the following:
    • To move the image, drag it.
    • To resize the image, select it and then drag one of its handles. Press the Shift key when resizing the image to maintain the original proportions.
    • To change the image properties, right-click it and choose Properties.
    • To delete the image, right-click it and choose Delete.
Nov 18, 2009 | Adobe Acrobat 7.0 Professional
Storage path
On removable memory cards. Panasonic iPalm Digital Cameras are equipped with an SD Card Slot which allows the camera to store images on EITHER an MultiMediaCard (MMC) or an SD Memory Card. Simply insert an MMC or SD Card into the camera, take pictures until the card is full, then remove it or replace it with a fresh card. You can selectively erase any or all of the images from the either the MultiMediaCard or the SD Memory Card and reuse it. Storage capacity for the PV-DC3000-A (based on included 16MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 13 images Fine Mode (2048x1536) up to 27 images Normal/2x Digital Zoom Modes (1024x768) up to 69 images Burst Recording Mode (1024x768) up to 82 images 3x Digital Zoom Mode (640x480) up to 150 images Motion Image Recording Mode (12 sec. max./320x240) 9 sets TIFF Mode (2048x1536/no compression) 1 image Storage capacity for the PV-DC3010 (based on included 32MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 29 images Fine Mode (2048x1536) up to 57 images Normal/2x Digital Zoom Modes (1024x768) up to 145 images Burst Recording Mode (1024x768) up to 172 images 3x Digital Zoom Mode (640x480) up to 315 images Motion Image Recording Mode (12 sec. max./320x240) 19 sets TIFF Mode (2048x1536/no compression) 3 images
Aug 31, 2005 | Panasonic iPalm PV-DC3010 Digital Camera
Storage path
Aug 31, 2005 | Panasonic iPalm PV-DC3000 Digital Camera
Record images
Quality Mode Resolution 14MB Internal Memory 256MB xD Picture Card 512MB xD Picture Card SHQ 2592 x 1944 3 images 69 images 139 images HQ 2592 x 1944 11 images 204 images 409 images SQ1 1600 x 1200 27 images 515 images 1030 images SQ2 640 x 480 144 images 2663 images 5324 images
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Internal memory
Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card SHQ 2288 x 1712 4 images 5 images 178 images HQ 2288 x 1712 14 images 16 images 523 images SQ1 1600 x 1200 27 images 32 images 1030 images SQ2 640 x 480 144 images 165 images 5324 images Storable movie length and resolution (approximate figures). The number of movies saved is based upon the storage capacity of the xD-Picture Card and length of each movie. Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card HQ 320 x 240 30 fps movie 20 sec. max movie 24 sec. max movie 12 min. 54 sec. movie SQ 320 x 240 15 fps movie 41 sec. max movie 48 sec. max movie 25 min. 48 sec. movie
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Bushnell NorthStar 78-8830 (525 x 76mm) Telescope Logo
24 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
