I have a Yorx 2108 stereo system; the turntable does not turn. We took it apart; there is a belt off. We do not know how to put that belt back on. Is there a site with pictures, or a video, that anyone knows of? Thanks, Cami
fire sine
  • 382 Answers
SOURCE: Teac turntable belt came off.. help!
Through the 2 holes on the platter, lift the platter up. Take the belt, flip the platter over, and stretch it around the center ring. Flip the platter back over and turn to so one of the holes is over the spinning motor. With your finger or with a blackstick, stretch it back onto the motor head.
Also check the belt for wear....that should do it.
Keep me posted.
Posted on Dec 16, 2007
  • 156 Answers
SOURCE: putting dryer back together
if whirlpool are kenmore the pulley slides in tobottom of the dryer in front motor there a slot it goes in
Posted on Feb 28, 2008
SOURCE: cassette drive belts
Here's a link to a site that has instruction on measuring drive belts. I have a Yamaha MT-400 4-track recorder with a warped belt and am trying to get it working again.
http://www.ceitron.com/passive/belt.html
Posted on Apr 26, 2008
djproaudio
  • 515 Answers
SOURCE: Optimus 1000 belt drive automatic turntable
Usually, for most turntables, the belt goes on the bottom of the platter first. Then you put the platter back on the turntable. From here you should see an opening on the platter where you can 'grab' the belt. Pinch the belt, and then wrap it around the rotating motor's shaft. This is usually at the top left side - around the 10 o'clock position.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
djproaudio
  • 515 Answers
SOURCE: drive belt on Sony turntable
- OPTiC
www.1200s.com
I was just given a Yorx FM 2502 system. I think the turntable needs a new needle.
The "stylus" to give it's correct name, is always connected to the cartridge it fits in. That should have a make and number on it. If you put that into Google search, it should come up with the correct stylus. General they just slot in and out of the cartridge.
Feb 17, 2016 | Yorx Audio Players & Recorders
I have an compact disc stereo system, disc,radio works. phono not working, why ?
I live in California but I do have a memorex system with the same components. My belt fell off my turntable so it didn't turn. It took a bit of patience but I was able to get the belt back on. The turntable is held down by a clip on the spindle. The belt might have to be replaced if it keeps falling off. It will do that if its been used alot. While the turntable is off, if you move the arm you can see if the turntable motor will turn on too. That would be the only other problem you can have on that unit. The repair cost might be more than what the unit cost. Just be patient and careful and you probably can fix it yourself.
Jul 19, 2014 | Memorex Nostalgia Turntable and Stereo...
Yorx turntable speed issue, And turntable is warped.
You may be experiencing Acoustic Feedback, although it doesn't really make any sense the way you describe it. Make sure the tonearm is balanced and the proper weight is dialed in on same. Does it make any difference if the volume or bass are turned down, which my point to the Acoustic Feedback.
Jul 04, 2012 | Audio Players & Recorders
Need instructions & diagram for belt replacement
its simple, the belt goes around the platter and the motor spindle, thats it!
Jun 05, 2009 | Audio Players & Recorders
How belt goes back on
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
Jan 02, 2009 | Emerson EM-MS9838 Shelf System
Aiwa stereo turntable system px-e860k
how long have you had it? could be that you just need a new belt if it keeps slipping off...
Oct 02, 2008 | Audio Players & Recorders
Turntable help
Sep 20, 2008 | Aiwa PX-E860 Turntable
Phono chord pins broken off
parties can be rough on audio gear
most turntables I've seen have male rca (phono) plugs on each end, but you have to get to the inside either by taking off the bottom or in some cases the body comes apart in two halves. If you get there and it turns out to be a solder on type (not likely) you can get the tails at radio shack. Most people with any audio equipment at all have an rca stereo pair lying around somewhere.
OR
if you can solder, you can just put new rca ends on the existing cable . Good luck.
at least he didn't break your needle
Jan 22, 2008 | Audio Technica AT-PL50 Turntable
Stopped Turning
I had a similar problem, what I ended up doing is taking it apart and jiggling the wires, the motor runs now, but when i opened it up, the belt was losely laying there, how do i put the belt back on? thanks.
Dec 13, 2007 | Crosley CR49 Shelf System
41 people viewed this question
 Grubhead
Grubhead
