I'm having the same problem... Only when I click my PS button, it flashes, normally. Then again, it's faint, and very, very fast, machine-gun-like flashing. And it's really annoying. Who knows how to fix this problem? I've tried resetting, there's no way to connect the controller with the console it's self, I've tried using the wire to connect it... No luck, nothing's happening. Please help?
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
me too. i get this problem . i have a wii dance pad that has a gamecube connector , and i guess the DDR doesn't detect it as a dance pad , but as a gamecube controller . so think , you can't hold the nunchuck and the gamecube controller at the same time . so i guess we need a wireless dance pad for the nunchuck to work as well .
I have had the same problem with my MadCatz PrecisionAIM 360 Controller. It is because of MadCatz low quality standards. Basically the only way to fix it is to open the controller and re-solder the connections
1. Hold the power switch on the 4 controllers till the blue light at the bottom of the controller stays on.
2. Once all the blue lights are on the controllers, hold in the button on the USB stick till it blinks.
3. Tap the button on the side of the USB stick and all 4 controllers will sync with the system.
