Question about Brother ML-300 Typewriter
I fed a paper into the typewriter and was typing and using the machine as normal, and suddenly a sound like a metal part of the typewriter becoming dislodged and falling occurred. I tried looking at the particular part - it appears that the metal plate laying just against the roller where the paper is fed onto has become unattached and now is somewhat hanging loosely against the roller and prohibiting me from feeding paper into the typewriter.
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support, poke around in there you will find a downloadable manual.
DickyO
Posted on Sep 30, 2010
IBM Wheelwriter 6 Typewriter - while typing, characters just quit printing on paper. Checked ribbon, machine etc. Everything checked out?? What could be the problem.
It is probably the print solenoid that has a broken cap. I have seen a few advertisers that sell the repair kit with instructions. It is fairly simple to repair.
Jan 02, 2014 | IBM Wheelwriter 6 Typewriter
While typing there was a metalic "clunk. The paper would no longer remain around the bar.
There is a strong spring tha holds the lower rolls on the paper it may have broken but more likely the plastic point where it hooks broke off.
DickyO
Jun 24, 2012 | Brother SX-4000 Typewriter
On my wheelwriter 6, when i type everything goes through the motion but it want type any letter on the paper. I change the ribbon and install fresh batteries?
There is a part on the print hammer solenoid that falls apart over time. It is a small whiteish cap that
just falls apart so the machine sounds and looks like it is working but there is nothing being transfered to the paper. I have ordered this part from Coleman manufacturing.
Jul 06, 2011 | IBM Wheelwriter 6 Typewriter
Paper will not feed through after replacing color
Good day, I suggest you must clean the roller and and use appropriate type of papers. to clean the roller, press power button to turn on the machine then remove any paper from the auto sheet feeder. press menu until maintenance appear the press ok. and try to load load 3 or more a4 letter sized paper and see if the the paper is automatically fed in and then out of the machine.
hope this will help you. have a nice day.
Jul 31, 2010 | Canon PIXMA MP240 All-In-One InkJet...
My typewriter all of a sudden just stopped typing letters. im not sure if the ink has run out...it wasn't fading or anything before it stopped working mid typing
The ribbon might have fade out, please try and replace the ribbon or check the ribbon selector if is not for stencil cutting. If is in stencil cutting it wont print on the papers as u type. Thanks
Apr 29, 2010 | Brother ML-300 Typewriter
Hi, I am having a problem with my Model GX6750 typewriter. While I was typing it started typing on its own. It typed a line and a half then I shut it off. When I turned it back on it is not typing the...
Sounds like the machine may have a staple or paper clip on the electronic circuit board. Turn OFF and UNPLUG the machine. The main circuit board is located under the keyboard, so tilt the machine towards the rear (on its back) and listen for anything loose in the machine. Look inside and locate the foreing object. If necessary, tun the machine upside down and shake up and down. Do not turn the machine back on until you have removed the foreign object.
Nov 22, 2009 | Brother GX-6750 Typewriter
Remove a label stuck to the metal floater behind the pleten myself
Take a quarter piece of typing paper. Soak it in paint thinner. Roll this down where the label is stuck. The paint thinner will dissolve the adhesive on the label but will not harm anything in the typewriter.
Apr 24, 2009 | Brother ML-100 Typewriter
Display arrow pointing to "NP"; Typewriter won't type on paper.
NP means normal print.  to change the print mode hit the MODE button
Jan 13, 2009 | Nakajima AE-740 Typewriter
Brother ML-300 Typewriter Logo
63 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
