Question about Mitsubishi VS-60607 TV
I replaced both convergence IC's. It works fine For about 3 minutes. Then starts to roll. I UNPLUG IT FOR 10 MIN. PLUG IT IN 3 MIN. IT STARTS ROLLING AGAIN.
    President:
  • 4,402 Answers
Picture is rolling sometime double images after awhile it stops and then starts rolling again
Ur tv convergence are dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 25, 2010 | Mitsubishi VS-60705 60" Rear Projection...
Rolling green horizontal bar from top to bottom,then bottom to top and so on. sometimes rolling fast,sometimes slow and sometimes the green bar stops in the middle of the screen.every once in a while the...
This TV needs a service adjustment done. Looks like a vertical or horizontal IC is failing. I'd go ahead, and shut off until services adjustment is made. Have you unplugged for a few minutes and plugged back in? However, I'd have a service tech look at it.
Oct 25, 2009 | Mitsubishi WS-48513 48" Rear Projection...
96 s10 2.2 4cyl. running lean . It has new fuel pump and fuel filter. I've checked the converter, new 195 degree thermostat,changed fuel regulator,changed front 02 sensor, changed coils and Diagnostic tool...
I know you said new fuel pump and filter but I would recheck the fuel pressure. Drive the vehicle with the fuel pressure gauge on it and see if the pressure drops after 10 minutes.
Sep 02, 2009 | 1983 Chevrolet S-10
Horizontal convergence line rolling up the screen
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation and let them recommend an authorized service center in your area. but this is a rather serious problem...
thank u
rate me!!
Jul 15, 2009 | RCA Televison & Video
Vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Nov 23, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Help me please b4 my fiance breaks it..
Good Day, krakdsanity;
It's an easy fix, but maybe not cheap. Not knowing the Model #, I would suspect; C2p05 100ufd 16volt off pin 3 of IC2P01 (9-volt regulator) both are on the signal board.You may not be able to repair yourself but you will know what's wrong when you call an an Authorized Service Center. Cost on your type TV varies but should be about $550.00 if they come to your home. Make sure you get a written estimate first. Good Luck,big IRISH.
Aug 31, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Rolling screen
Ahh the old rolling picture problem. If this set has a Picture in picture feature, your problem is on the PIP module itself. There is a kit of surface mounted capacitors that need to be replaced If you have some soldering skills you should be able to do this your self, but if you do not, I advise you to get someomne who does as most of these PIP modules are not available any longer. The kit can be purchased from http://www.mcminone.com/search.asp?keyword=Mitsubishi+PIP+kit&btnSubmit.x=6&btnSubmit.y=7 Good Luck
Mar 28, 2007 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi VS-60607 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
