Question about LG DLG5988 Gas Dryer
Dryer no heat blowing cool air I already clean the filter
There is a sensor switch/button that trips when dryer gets too hot. This will turn off the gas ignitor to the dryer. You have to go to the back of the dryer, at the top, remove three screws and remove the top, Slide the top off and remove the screws to the control panel, and the screws that hold on the front door panel. Under the left side of the heat flu inbetween the two wire is the sensor switch or button, press the button and wellah, you are back in business. Vacuun out the lint, which, this is the reason it tripped the sensor, and reassemble your dryer.
Posted on Oct 02, 2011
  • 489 Answers
You have one of 3 problems. No gas, high limit switch problem or motor circuit is broken. You will need a professional LG technician to diagnose the problem.
Good luck
Posted on Oct 04, 2010
Dryer wont heat for more than 10 minutes when cold
did you clean the vent line?THAT COULD MAKE IT RUN HOT THE AIR CAN'T BLOW OUTSIDE,BUT WITH THE DRYER HAVING HEAT WHEN IT STARTS AND THEN AFTER LIKE 10 MINUTES NO HEAT IT SOUNDS LIKE YOU HAVE BAD GAS COILS,WHEN THE COILS ARE STARTING TO FAIL THEY WILL WORK FOR LIKE THE FIRST 10 TO 20 MINUTES AND WHEN THEY HEAT UP NO GAS,WHEN THE COOL THEY WILL WORK AGAIN,I WOULD CHANGE THE COILS AND CLEAN OUT THE DRYER AND VENT LINE,THIS SHOULD BE DONE ONCE A YEAR SO YOU DON'T HAVE A FIRE AND YOUR CLOTHES WILL DRY ON TIME,EVERYONE THINKS SOMETHING IS WRONG WITH THE DRYER AND ALL THAT HAPPENS IS THE VENT LINE AND THE DUCT WHERE THE LINT FILTER SLIDES INTO FILLS WITH LINT AND THE AIR CAN'T BLOW AROUND GOOD ANYMORE,ALSO WITH A SHOP VAC VAC UP THE LINT WHERE THE BURNER AND MOTOR IS AND THEN SET THE VAC UP TO BLOW AND BLOW THE MOTOR AND GAS BURNER OUT,DO THIS AND YOU'LL HARDLY HAVE ANY PROBLEMS WITH THE DRYER
Sep 30, 2017 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
I very recently-9/28/13- purchased an LG clothes dryer-model #DLE487OW. A breaker was kicked and since the electrity was restored, I am getting a check filter message with cool air only blowing in dryer. ...
Call LG people before you call the service man.
Really, you have no heat. Check out the heating circuit...heater, t/stats; vent. etc. Something is sensing that the filter is blocked when it is not....check air flow.
I doubt the board is a problem at this point.
Oct 18, 2013 | LG Dryers
Dryer wont stay lit
if the flame is liting most likely problem is bad air movement.go outside with thedryer running and check the hood to see how strong the air is blowing out,if there's a cage or anything blocking the hood remove it,if the vent line is a long run remove the vent line from the back of the dryer,stick a leaf blower into it and blow out the lint to the outside.also with the dryer unplugged,remove the bottom panel,remove the lint filter and metal duct the filter slides into,clean that out and blow out the blower wheel with a shop vac,you can blow out the gas tube where the flame ignites to make sure it's clean blow off the motor and the cabinet and vac up all lint that blows forwards.you can try running the dryer with the vent line removed to see if it runs any better.when the dryer first heats up the flame will come on until the temp. is reached and it will shut down,one more thing to check,when gas coils start to fail you'll have heat for like the first 15 to 30 minutes,then when the coils heat up the ignitor will glow but no flame,after the coils cool down they will work again.how are you running it on timed dry or more or less dry,if you run it on auto or more or less dry there's a sensor inside where the lint filter is,try cleaning it up or try running it on timed dry to see if it runs any different,when on auto the heat comes on,when it reaches temp. the heat stops and the timer will advance,when it calls for heat the timer stops and the heat comes back on,it will do this until the clothes are dry.your model has an even heat board in it that can also cause problems but if the flame is liting it sounds like you have a block somewhere.go here this will tell you a little more about your model dryer.
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
May 23, 2013 | Dryers
GE gas dryer DSXH47GGWW- starts fine and begins to heat up then shuts off with a message that the lint filter needs cleaned. The lint filter has been completely cleaned and vacumed inside, outside and...
With no lint anywhere around the dryer the thing to check if havent already is the venting itself to see if outside it is blowing and not restricted or blocked
The control is sensing poor air flow and throws up the "clean filter" when air flow is restricted all be it from the filter clogged, or blocked/restricted vent
Gene
Aug 25, 2011 | GE Dryers
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
Dryer not going to cool down cycle, thermal fuse failed 2x
Most problems like this arise from air flow problems. You need to break down the dryer and clean out the lint. Including removal of the filter housing.making sure your outside vent is clear as well.If that fuse keeps blowing you especially need to remove and rinse out that filter housing.
Dec 30, 2008 | Whirlpool LER4634J Electric Dryer
LG DLG5988 Gas Dryer Logo
111 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
