Question about Home
I can't turn off the hot water in a dual faucet shower unless I push the handle in
  • firemant Sep 29, 2010
    In most brands, remove a protective cap, labled H, with a small flat screwdriver. A screw, usually philips comes out next. This alows the handle to be removed. Then There should be a nut of various sizes. Remove this nut, counter clockwise. The valve should be ready to remove. Some pull straight out. Some turn counter clockwise to remove.
    In some cases you can replace the whole valve and any washers and o-rings inside. In some cases, You can buy a replacement kit for these. In older faucets 'usually brass', you might need to replace a worn seat, inside the fixture. This requires a seat wrench. Usually an L shaped steel bar with both ends tapered into a square.
    New Friend:
  • 50 Answers
Check the cartridge and seat but make sure that you close the valve or riser for your line in washroom
Posted on Sep 30, 2010
I have two vanities and a shower in the bathroom. We only get hot water to the sinks when we turn on the shower to hot. Even if we turn off the shower we will still get hot water for a while. It just seems...
Check the water supply lines to the shower at the faucet handles. If the fitting for the hot water line connected to the handle is loose, it can twist and kink off the water supply further down the line when you turn the faucet handle. I'm not exactly sure how this could be relevant otherwise, but under normal design circumstances this type of scenario with your shower wouldn't matter for other faucets.
May 01, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Oct 09, 2010 | Delta & Single Handle Shower Faucet
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Jan 13, 2010 | Delta & Single Handle Shower Faucet
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Jul 20, 2009 | Delta & Single Handle Shower Faucet
No water flow
Did this unit come with water stops built into the faucet body? Some of the newer faucets have stops built in and they need to be turned on. Also if you aren't going to plumb the hot in, you will need to cap it off but it should run without it unless it has some sort of balance in it. I don't think so though.
Apr 09, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
26 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
