Question about Vacuums
Mitsubishi stamina strong tc-ah8j vacuum manual
  • Vacuums Master
  • 3,083 Answers
I checked my usual sites but couldn't come up with the manual. Not going to be easy to do, since I suspect that Mitsubishi sub-contracted these machines. You best and maybe only shot (shy of finding an owner that would copy one for you) would be to contact Mitsubishi and see if they can run one down for you. Here's their suppor numbers:
http://www.mitsubishielectric-usa.com/search/prl.html
And here's their support site:
http://www.mitsubishi-presentations.com/customercare/tech_support.html
Good luck, and hope this helps.
Posted on Sep 29, 2010
MANUAL FOR KENMORE 2 IN ONE CORDLESS 14.4 STICK
Try this link http://i.sears.com/s/d/pdf/mp-tc/10128154/prod_1618350412
Or google
Kenmore 10340 14.4-Volt Cordless 2-in-1 Stick Vacuum Scroll down the page and you'll see a link to the manual
Feb 12, 2016 | Kenmore Vacuums
My Dyson dc14 vacuum is making flapping noise and loosing power, strong burning smell
If the air flow is blocked, then yes you will get overheating of the motor and a funny smell. One approach is to remove the part closest to the motor, and if the motor then runs okay, the blockage must be downstream. Perhaps there is an online manual that explains how it comes apart? Another thought is that the bearings might be going bad. Might be worth taking this vacuum to a repair man.
Aug 23, 2014 | Dyson DC14 Bagless Upright Cyclonic Vacuum
I need the Manual for #2100 Electroluks vacc
Service manuals for the Electrolux vacuums, including the accessories, are only available to the franchise owners and service techs.
Also, having said that, I don't recommend fixing the switch yourself. Replacing the switch involves disassembly of the canister, which is a bit complicated. Putting it back together correctly, without crimping wires. even more so.
I used to be an Electrolux service manager and have seen vacs brought in in pieces. Customers had succeeded in dismantling the machine, but were unable to reassemble it. Or had cracked or broken a piece. This makes the repair more expensive.
Or machines were brought it that had been reassembled incorrectly and wouldn't work. Or worse had shorted out due to crimped or incorrect wiring.
I strongly suggest taking the vacuum to a repair shop that is familiar with the older Electrolux vacuums, in this case the plastic models.
Mar 06, 2014 | Electrolux hose 2100 series diplomat
Suction from hose isnt strong enough. Vacuum
There is probably a clog on the U channel (little Gray tube that attaches to the Vac tubing). Pull it loose and look in side all the tubing.
Nov 16, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My bissell lift off will not pick up, there are no blockages and suction is still strong
You can fix it easily. All you need to do is change the belt and you'll be good. Here is a link to the belt you need and the manual which has instructions.
Bissell Lift-Off Revolution Belts and Manual
Bisslll Lift-Off Revolution User Guide
Nov 15, 2009 | Bissell 3750 Lift Off Bagless Upright...
My vacuum will not pick up even fuzz on the carpet
If the suction is strong through the hose and its still not picking up, then something is definately clogged despite the strong suction and rolle brush. Check all inspection tubes including the main dirt channel behind the roller brush. You may find something that keeps getting in the way when dirt or hair is trying to bypass through.
Jan 23, 2009 | Kenmore 31913 Progressive Direct Drive...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
