Question about M-Audio Studiophile BX8a Speaker
Humming BX8 I have not opened it up yet. I would like a schematic on it before doing sol I doubt it being a cracked speaker cone, etc. They have not been driven that hard. I suspect capacitor probelm in the the prower supply but wthout a shenmatic, I am hesitant to starr poking around in there. Could I carry it to any shop that works on amps like guitar, bass, etc? I am not afraid of trying it myself if I know what is in there. I have worked on power supplies many time before in the old days with TVs. John
    Brigadier General:
  • 6,966 Answers
I would have to agree on the possibility of the power supply/capacitor, zener,/regulator and/or diodes.. I sincerely doubt if the circuitry inside would be that too complicated and expect that you can wing it. Other than the power supply, perhaps you may also consider:
1. grounding/shielding of the signal input; and
2. a partial short in the amp section thereby drawing excessive current which would result to the humming sound.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 25, 2008
How do I fix my sound on the pc? speakers are cracking.
Sounds like the speaker cones are torn. They're made of a paper and break easily on load sound volume. open the speaker to check it.
Hope this helps.
Feb 23, 2015 | HP Computers & Internet
How to take the big speaker out of a studiophile BX8 speaker
As you can see, there are 8 screws holding the woofer in. Remove them, lift the speaker up, but before you disconnect it....Mark + and - onto the + and black -. .
Aug 18, 2014 | M-Audio Studiophile BX8 Main / Stereo...
How to remove tweeters maudio bx8 speakers
Remove the backplate and the wires are often hold togeter with a tiedrap, so you need a long , how do you call it in english:) , sciccoskind tool or you can try to unplug, the plugs between the powerunit/ amplifier and you speakers . I'm busy rebuildimg m3-8 from m-audio, cause of some where cheap amp/powerunit and did it by hand and i have large hand, but put some tape around the backplatesurrounding for scratches.
And if you have them loose you can remove them.... but why?
Do you think you just can replace them for other once, think again
Jul 10, 2014 | M-Audio Studiophile BX8 Main / Stereo...
Cracklin/popping with m audio bx8 d2's thru fast tack mk2
Check for flucuations in your power supply. If none then put a shield sleeve on your cord.
May 03, 2012 | Avid M-Audio BX8 D2
My Fender Super Champ works with Line out only. Is this a tube issue? I dont get a hum or any sound out of the speaker. This is less than a year old.
Here is your schematic:
Scroll down to "get manual" and click to download. IGNORE other downlooad links.
As you can see, the line output comes right from the output transformer... IF the wiring is still connected to the speaker then LIKELY you are going to be buying a new speaker for the unit as the voice coil is blown. With the leads unplugged from the speaker use an ohmeter to check continuity. You should see around 5 to 8 ohms resitance. You can also connect a battery across the speaker leads and note if it generates sound... if not you can have it re-coned or replace it. Re-coning usually costs 2/3 of the cost of new speaker.
Aug 14, 2011 | Fender Super Champ XD Guitar Combo Amp
if no sound from both speakers check fuse,
if some hissing or humming on full volume then its a fault in oscilator section
if there is no hiss or hum at full volume its a breakage in the wires of speakers, if one speaker is ok its aagain a wire open problem in out put section
open up the speakers and just apply 1.5 volts dc for fraction of second to the speaker leads , if theres crackling the speaker is ok
also see for torn out cones or stuck cone or speaker coil open.
Jan 16, 2009 | 1992 Mercedes-Benz 190
Humming BX8
Hello docjgg,
This sounds like it may be a loose connection (ground) generation common mode noise or it may be a capacitor in the power supply going bad and not providing enough filtering of the AC voltage (allowing for 60 cycle hum). You should get a schematic for the speaker or just take some rule of thumb measurements of the power supply output, with an oscilloscope (you will be looking for ripple voltage, what you could do is use one of your good speakers as a comparison of good to bad.
If you do not want to work on this yourself, you could take the speaker to any TV repair shop or audio repair shop.
I hope this helps
Thank you,
May 25, 2008 | M-Audio Studiophile BX8a Speaker
BX8A studiophile monitors distortion problem
it could be a loose connection or the cone is cracked inside , the only way to find out is to open and take a look inside ,check the connections , the 2 wires from box to speaker, ALSO CHECK where the cone meets with the magnet , hope this helps AJ
May 14, 2008 | M-Audio Studiophile BX8a Speaker
Bx8 monitors problems
You will need to REPLACE THE WOOFER / DRIVER on this unit. Cost for a new driver is about $80.
Nov 04, 2007 | M-Audio Studiophile BX8 Main / Stereo...
Open Questions:
See all M-Audio Studiophile BX8a Speaker Questions
M-Audio Studiophile BX8a Speaker Logo
262 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
