Question about Dyna-Glo (PPH16-LP) Utility Heater
NEED A BLOWER FOR MY DYNA GLO HEATER WHERE CAN I GET ?
Buffalo12980
  • 625 Answers
SOURCE: dyna-glo
try this site - they have dyna glo parts
http://www.robinrents.com/heaterparts.htm
Posted on Dec 11, 2007
SOURCE: Dyna-Glo RMC95C6 Kerosene Heater
I have uploaded the manual for all to use here.
Posted on Nov 22, 2008
SOURCE: dyna glo kerosene heater
smoking problem
Posted on Nov 23, 2008
SOURCE: E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Posted on Feb 09, 2009
SOURCE: dyna glo workhorse heater
you need to pull top cover off. And bend the igniter in to the spray of fuel and check the gap of the ignighter to 3.5 mm and bingo should work i just bought one and had to do this to it
Posted on May 06, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
I have a RMI-70LP Dyna-Glo 18,000 btu unvented room heater. Can it be converted to natural gas?
These can be converted by changing the orface on the heater and also the regulator. Best to contact your gas company or Dyna Glo to obtain the correct orface for that particular heater.
Oct 08, 2009 | Dyna-Glo Heating & Cooling
Kerosene heater
Dyna Glo 95 c4 Manual
http://www.owneriq.com/mdownloads/8979e0af-dfee-45f1-a8ba-c05c2f5ed4a8.pdf
Jan 31, 2009 | Dyna-Glo RMC-8001SS Heater
Dyna-Glo natural gas space heater to propane gas.
Yes it is possible and a good idea. You need to have a regulator installed to reduce the pressure to the heater and this is a simple procedure. Contact your local Propane distributor and they will probably do this free to get your business.
Ray
Dec 08, 2008 | Dyna-Glo Heating & Cooling
A blower you can hook up to the dyna-glo wall mount heater
only if there is one for the particular model heater you have ck with dealer in your area
Nov 24, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Filters for dyna-glo pro
You can make your own filters out of felt and I have also found that with some minor modifications most of the parts from Mr. Heater will work with Dyna Glo. I have a 170btu kerosene heater and just installed an ignition, a high limit control and a flame sensor from Mr. Heater and it works like new.
Nov 03, 2008 | Desa International ALL-PRO® SPC-85 Utility...
Dyna-glo
Dec 11, 2007 | Heating & Cooling
Dyna-Glo (PPH16-LP) Utility Heater Logo
73 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
