Question about Troy Garden
My riding mower stopped as if the spark had been cut off. I tried to start it and absolutely nothing happened, Could the alternator be bad and it shut off the engine once the battery drained?
    Scholar:
  • 150 Answers
Probably not. The machine doesn't need alternator to run the mag fires the ignition, the alternator only replaces juice the battery used to start it. Eigther ignition unit failed or one of the safety switches. If I had to bet, my money is on safety switches.
Posted on Sep 29, 2010
MTD 638 lawn tractor does not spark on starting. Cranks but does not start. Changed ignition coil and spark plug still does not have ignition
Something must be stopping ignition do u have a oil level sensor on the engine sometimes the sensor goes bad or low oil in block cuts off ignition..
Nov 07, 2016 | Mtd Garden
Why doesn't it start?
Might be a full tank of wet gas from over-winter condensation.
Apr 11, 2016 | Troy Bilt 175HP Manual 42" Riding Mower
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
Wheelhorse toro riding mower will not start, was mowing, shut it off to take a break, went to start again, nothing, will not turn over, spark plug is good, gas is good, oil is full,
Use a multimeter to check battery voltage. You may have a bad battery or alternator circuit problem causing it to fail to recharge. You might try jumping it with jumper cables from a car/etc 12V battery.
If this does not help, also check the switch under the seat as some are wired so that you have to be sitting to run it and if that switch fails then the design assumes you aren't sitting on it.
Oct 21, 2013 | Garden
I WAS RIDING MY MOWER, WHEN I DECIDED TO CUT SOME GRASS, I STOPPED THE MOWER, PUSHED IN THE CLUTCH, ENGAGED THE BLADES, THE BLADES STARTED MOVING, I THEN PUT THE MOWER IN FOWARD LET OFF THE CLUTCH AND...
2 things, one, the belt jumped track, broke, or melted in place, 2, the hydrostatic ****** is out of oil, you didn't say if it was hydro or not. I doubt that the gear box has gone bad, but I would put more blame on a belt or pulley. Check it out. Hope this helps.
Mar 17, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
PTO stops, I turn the engine off then it won't start I have to charge the battery to get it to start. Its a model 1180
You may need to consider that the alternator on the engine is bad. The ignition coil provides the spark, but all other electrical functions have to come from the mower's electrical system. When running the alternator charges the battery, allows you to use an electic pto. If the alternator is not functioning, then the battery takes the electrical demand, ie the electric pto. When the pto stopped functioning and you were unable to start that is because the battery was drained by the electric pto. This is like the alternator on your car going bad, and at night the head lights get dimmer and dimmer, and I can tell you from experience when the guages fail the ignition is about to fail. Anyway, enough of the flash back, I would start by testing the alternator. Do you have a voltage meter on the dash of your mower? If so, usually it will jump up and after starting, if it does not then that is another symptom of a bad alternator.
I hope this helps get you going. Please let me know if you run into problems or what your final result is.
Aug 08, 2011 | Cub Cadet Street Sign- tractor lawn riding...
The engine will run if I hook up jumper cables to
the on board electric system is not working, you lose your spark when you remove the jumper cables, this tells you the mower is not making its own electricity. So either the alternator or its regulator, or both have gone south.
With the engine running, you should have just above 12 volts at the battery.
So find a manual, locate the alternator/generator, and be looking in that area for a broken connection, blown fuse, or bad component.
Jul 28, 2010 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
I was riding my cub cadet riding mower the other day and shut it off to take a break. When I went to start it again the engine wouldn't even turn over. There was absolutely nothing! I checked the fuse and...
have a look at the seat cut out switch????
if this is not switching on you cant start the mower
its a safety switch,,saves you chopping your feet off?
Jun 02, 2010 | Garden
I have a riding yard machine. It does not seem to
Sounds like the alternator under neath the flywheel has gone bad. This could happen from jumping the mower of a vehicle still running. The alternator on the vehicle puts out to much power for the mower and will damage or blow the alternator on the mower.
Sep 29, 2009 | Mtd Garden
Garden Logo
190 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
