Question about Toto Drake ADA Compliant Toilet with Elongated Bowl
G-max fill valve does not shut off - Toto Drake ADA Compliant Toilet with Elongated Bowl
You might remove the tank lid and check the water level. If their is no water in the tank then the flapper or rubber dish covering the tank outlet is failing and needs to be replaced or if it is stuck in the open position: then correct reason for flapper not re- seating itself and allowing the tank to refil. If water is in the tank but is spilling over into the fill tube or the tube raising up from the tank outlet: then the water level is set to high or the fill valve shut off is failing. I think it is a float type under the blue plastic cover. You might be able to use your finger to move the float. The float might be stuck or the diaphram might be worn out. Sorry, it's been over a year since seeing this valve and have to go from memory. All the parts if any can be picked up from your local Toto dealer and not the big box stores.
Posted on Sep 30, 2010
My air compressors filled up with air and shut off when the air got below a certain psi and did not kick back in to fill the tank can you help me.
Pressure problems can be several pressureline leaks
If an air pressure switch (pressostat) does not return replace the pressure switch a gray colored or white or black colored box with the powercables comin to and the power knob on it red black gay or other color. that is the problem itself in this case . the mechanic jumped not up it hangs , best is to replace the complete part.
If the compressor filling the tank and when its reached the pressure and it blow from out the safety valve then the pressostat its too high adjusted. there is a max pressure on the valve to read is it blow off below the max replace the safety valve.
Is your pressure is build up but it blow out the Pressure relief nipple its a part of the pressostat in most case , the your Non-return valve on the tank is dirty or by dirtable metal parts from the pressure line membrane parts .
Jul 19, 2017 | Psi Air Tools & Compressors
Miele CVA5065 coffee machine- the manual states : "fill the big plastic container to the max level". What is the volume to the max level?
Filling The Water And Coffee Bean Containers - Miele CVA ...
www.manualslib.com > ... > Coffee Maker > PW 5065 > User manual
Miele CVA 5065 Manual Online: Filling The Water And Coffee Bean Containers. Thecoffee machine must be cleaned thoroughly (see ''Cleaning and care'') before you... ...up to the "Max." mark. A valve at the front of the water. container will ...
[PDF]Operating and installation instructions Built-in coffee ...
Nov 25, 2015 | Miele Coffee Makers & Espresso Machines
Y dose the john dear 6330 run hot all the time even after it blowen out
Engine or hydraulic system overheating clearpix.gif clearpix.gif clearpix.gif clearpix.gif clearpix.gif clearpix.gif Coolant system low on coolant in 6020, 6030, 6030 Premium, 7020, 7030 and
7030 Premium Series Tractors.
]clearpix.gif//-->
Symptoms
After several hours of work, warning system indicates hot engine coolant or hot hydraulic oil.
Situation or Problem
Coolant level in reservoir is between the "MIN" and "MAX" range but engine or hydraulic system is overheating.
Summary
Air is entering cooling system, hindering coolant flow. Check coolant level. Fill to the "MAX" line on the coolant reservoir.
Bleeding Cooling System:
The bleed valve (see Operator's Manual for location) on the radiator must be closed when the tractor is operating. Open the valve when coolant is drained or filled. If the bleed valve is left open, coolant will internally bypass between the low temperature circuit and engine high temperature circuit causing overheating. When bleeding the system, open the bleed valve and run the engine with no load for 5 minutes at 1700 rpm. Then shut engine off for 5 to 10 minutes before closing the drain valve. Check the coolant level. If level is below the "MAX" fill line, repeat this procedure until coolant level stays at the "MAX" line.
May 21, 2014 | Cars & Trucks
Have installed new Fluidmaster PRO45; takes 5 min. to fill tank. Flow through our pipe valve is strong. There was an insert in the inlet pipe to quiet the fill; we removed that and still takes 5 minutes....
Most likely either the shutoff valve or the fill valve is not opening correctly or is somehow clogged. First rule out the shut-off valve by turning it off, disconnecting the fill pipe from the toilet tank. Attach a hose to the loose end of the fill valve (duct tape will do) or point it out the window or into the shower. Now turn on the shut-off valve. If it doesn't flow like a fire hose, then the shut-off valve is the problem. You will have to remove the shut-off valve so, you might as well replace it with a new one. If the shut-off valve is NOT the problem, then you might as well disassemble the fill valve and you may be able to remove debris from it. Or just replace it. Good luck!
Mar 11, 2013 | Plumbing
Recharge a/c i have r12 which valve do iuse black or red
line that goes to compressor is low side line out of compressor is high side
always fill on low side
also r12 hase been band for sevral years and should not be used
if this freon is r-12 conpatible or replacment then your fine
after leak been repaired and system pressurized and vacumed out
start engine put a/c to max blower motor to hi open windows
conect your fill bottle to low side open valve and system will start filling
when freon reach enougt pressure the compressor should start and draw in
the freon if it fails to start you could jump the low pressure swich to help draw in
freon when system has drawned its capacity shut off your bottle and disconect your line to fill
cap off the valve
if compressor fail to start you have another issus could be electrical
take CAUTION doing repairs to a/c system
Apr 02, 2011 | 1989 Toyota Camry
I got one of your compressors off a friend that had not used the unit in years, it say in his garage and collected dust. So I changed the plug and wires, got a new outlet in my garage for a 230 line and...
With pressure in tank test for leak at the check valve. Follow the discharge line from the pump to the tank. There you will find the checkvalve (usually brass valve). If the check valve leaks the compressor will be under load when motor tries to start and will probably trip breaker. Look for reset button (red button )on the compressor motor and push-in to reset. With pressure in tank the motor /pump should turn freely by hand. If checkvalve good and unit turns freely, test capacitor for proper valve. It should test to within 95% of printed uf/mfd. Good holidays
Dec 15, 2010 | Puma Air Tools & Compressors
I have a Toto toilet with a G-max valve. It does
Your local home center should sell a "Korky Model No. R528" to fix the valve without removing it. It's the cap that contains the washer. Replacement is easy and takes just a few minutes. Once you have the cap off it's a good idea to flush the sediment from the valve body by holding a large cup upside down over the valve and turning the water on for a few seconds. The cup will keep the water in the tank.
Mar 08, 2010 | Home
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Pressure switch does not shut off unit and the
make sure your plugged directly to an outlet. no extension chords
tighten pop off valve colar
check oil / might be over filled
Jul 14, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Toto runs non-stop; won't shut off
float is sticking make sure it is moving up and down.or the float is set to low, the lower the float is higher the water level is.
Mar 24, 2009 | Toto Toilet Onepiece Ultramax ...
Toto Drake ADA Compliant Toilet with Elongated Bowl Logo
523 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
