Question about Acer Computers & Internet
Model P244W, Monitor goes blank. In the past I have performed the procedure of disconecting the power cord and then holding the power switch on for a couple of minutes and reconnecting the power and this has solved the problem. However, this no longer works.
    Brigadier General:
  • 3,917 Answers
Most probably the back light inverter board is bad.
LCD's use four small cold compact fluorescent bulbs to back light the display. (That's what gives the LCD its brightness allowing you to see it)
The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display.
If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad.
The inverter board and CCFL's are replaceable.
Also check the link bellow related to your query:-
http://www.build-your-own-computers.com/top-5-reasons-why-a-monitor-goes-blank.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Posted on Sep 29, 2010
My LG 2353 monitor screen goes blank by itself. Sometimes it will go into sleep mode or sometimes my screen just blanks out and the power light stays solid red without flickering to indicate whether or not...
shaylane_195, Good description of problem! But you left out one or two key things to tell me. Age of monitor? Approximate total "ON" hours of use? Is unit covered by LG (Lucky Goldstar) warranty? You and only you can tell me if the screen is really BLANK, or is it only BLACK? Do flashlight test to determine true state of screen! Can you see very, very faint image of WIN-desktop holding bright flashlight near your black screen? This monitor works!!! You just need to fix the possible (1) "cold, frosty looking, thermally intermittant solder connection on the "internal switch-mode-power-supply/CCFL inverter board. Yes, your monitor along with many other CCFL back-lit LCD units of all brands also could have some BAD, swollen, leaky electrolytic filter capacitors installed on the SMPS/CCFL inverter board which will need to be replaced with new ones of higher quality. Get back to me, lmistyrel on aim. or do additional comment on fixya, after you do some reading in my and other fixya tech's profiles to discover all options you as consumer/user have open to you. Bye for now. 12fixlouie
Mar 04, 2010 | LG W2353V-PF 23' LCD Monitor
Power ON, no display ,when switch off and on screen display for 1 or 2 second, again goes blank. model= LG Flatron -L1515s
check the power cords and the video connectors. if it's ok, then it could be a problem on video card
Feb 17, 2010 | LG Flatron L1515S 15" LCD Monitor
Monitor say clear paper jam then press ok. It indicates that the problem is at the back of the printer (the protruding compartment) but I have taken this off examined everything and there is definitely no...
The clicking could be because it thinks there is a problem. Try doing the procedure for resetting the memory on the printer...
(For step 4, do # 3, # 6 as well)
  1. With the unit turned on, Press the Power button and turn off the HP All-in-One.
  2. Unplug the power cord from the Wall Outlet and then from the Unit.
  3. Wait for 20 seconds , Plug the power cord into the wall outlet.
  4. Press and hold # and 9 while plugging the power cord back into the unit. Continue holding the buttons down until the display goes blank or it shows a message.
  5. If the printer does not turn on automatically, then turn on the unit by pressing the Power button & follow the instructions that display on the HP All-in-One to select the settings
Aug 31, 2009 | HP Officejet Pro L7680 All-In-One Printer
C6180 keeps powering on and shuts down immediately
Introduction Perform a semi-full reset to set all user menu settings, telephony parameter settings, country/region and language UI, fax memory settings, fax journal information, speed dial and broadcast lists, personal header information, and junk fax settings to the default settings. Performing a semi-full reset of the All-in-One
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
Perform a Soft reset:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01457329&cc=us&lc=en&dlc=en&product=1153494
Or a Full reset:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00720248&cc=us&lc=en&dlc=en&product=1153494
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
Compaq w17q monitor keeps going on and off how can i fix it?
1. check the power cords- make sure all are snug.
2. check and make sure no pins are bent in the cord to the computer
3. make sure that the monitor is not in auto-power save. Or in auto off mode. For example- is the light amber or green.
4. finally, make sure that your settings on your computer are not set to power off your monitor- as in a blank screen saver, power save or hibernate
Mar 26, 2009 | HP Compaq W17q Monitor
Monitor goes blank randomly
It is the capacitor on the power to the monitor. I have replaced about 5 so for. The capacitor is like 69 cents. Open it up and look at the circuit board where the power plugs into and see if any capacitor are bubbled up. If so then its a bad capacitor.
Jan 19, 2009 | Computers & Internet
Monitor goes blank
I was thinking about your problem, I just had a similar issue and the problem is that the inverter or the power supply with an embedded inverter had gone bad.
The reason it goes black is because the inverter fails to provide power to the LCD Display.
The only way to fix this is to open up the FPD:
*note these are instructions for the most popular FPD 1730*
1.there should be four screws on the back --> plus two large screws that hold the FPD stand and the Monitor together.
2.Open the back by pulling the cover off
Remove 7 screws holding the frame and the power button for the LCD
3.Remove two screws through holding a silver cover and remove cables.(pinkwhite) (blackwhite)
Please note where they belong before removal**
4.On the edges left and right are two screws 4 total ---> remove and remove LCD off of frame**becareful because the backlight Damaging can cause severe damage to your LCD panel.
5.Choose your model
Your FPD has 3 boards (power, inverter(backlights) Logic Video)
replace the inverter with well known good one
Your FPD has 2 boards(Power with inverter on edges, Logic Video)
replace the power board with a well known good one
6.Then do steps 1-5 in reverse order(putting your FPD back together.
I hope this is significant help
Sep 11, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Chi me monitor goes blank on screen save (does not come back on)
damaged power board replace it or replace the monitor
Apr 02, 2008 | Smart Modular SV3170A
Computers & Internet Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
