Question about Pioneer Audio Players & Recorders
Keeps powering off - Pioneer Audio Players & Recorders
    President:
  • Pioneer Master
  • 1,114 Answers
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
If you still have a problem, post a comment and I can help you further
Posted on Sep 30, 2010
Why my LG 840G phone keeps powering off?
If it is old it's the battery's inability to keep a charge. If it's new then the settings are on "power saver".
Sep 03, 2014 | Tracfone Wireless LG 840G
Keeps turning off
Everytime I worked on this set I have found bad connections in the power supply or on one of the inverter transformers
Dec 31, 2013 | Philips 42PFL5603D 42 in. LCD HDTV
My HP monitor keeps going to sleep,it reads (power button lockout) How do I fix this?
This is because the monitor's Power Button Lockout function is enabled. Press and hold the Power button for 10 seconds to unlock the Power button function. Your sleep problem should also be related to the lockout issue.
Dec 13, 2013 | HEWLETT-PACKARD Pavilion p6520f PC Desktop
CCTV power supply keeps decreasing the voltage
Your power supply appears to have a capacitor that is breaking down located within the diode bridge. You will need to replace the power supply or get it repaired.
Jul 16, 2012 | Optics
Pentair intellitouch electronic breaker keeps tripping
check pump see if popping or heater unplug auxs until it doesn't pop if keeps maybe bad transformer
May 04, 2012 | Pentair Intellitouch Power Center Includes...
My cd player keeps turning on and off. and dash clock light keeps dimming in and out and wont keep the time.
You have a loose wire. Will require removing the radio to get to the wire that keeps constant power to the radio ,,,this allows the clock to keep time. An interuption in this power source equal reseting the clock. Good luck
Feb 11, 2011 | 1992 Honda Accord
Green led keeps flashing no power on
Please read the solution on this thread; I keep repeating myself :-(
Bad power supply
Sep 06, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
111 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
