Question about Epson Office Equipment & Supplies
CANCEL REQUEST FOR HELP - I DIDN'T REALIZE THERE WAS A COST INVOLVED. Am changing ink cartridges for the first time on a Epson Stylus NX410 series. Even tho I have reloaded them several times to make sure they were in correctly, I get a message that says "Replace ink cartridges." Please advise asap as this an office machine that I need to use asap.
  • Epson Master
  • 4,737 Answers
Try the troubleshooting method. I've uploaded the Pdf file for you (click here). If you wish to download it, no problem, I've set the permission.
Need further help? let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 29, 2010
How to change ink cartridge in epson nx215
1. Turn on your Epson printer. 2. If a cartridge is expended, you see a message on the printer's LCD display screen. The icon on the screen indicates which color to replace. Press ink.13.7.1.jpg Start (NX210 Series) or OK (NX410 Series). If you're replacing a cartridge before you see a message on the printer's LCD display screen, do one of the following: NX210 Series: Hold down the Scan button as you press the Index Sheet button, then release the buttons. Press ink.13.7.2.jpg or ink.13.7.3.jpg to select Ink Cartridge Replacement, then press ink.13.7.4.jpg Start. NX410 Series: Press Setup, press ink.13.7.5.jpg or ink.13.7.6.jpg to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 3. Open the scanner. Note:
Your printer model may vary from the ones shown in this section, but the procedures are the same. ink.13.7.7.jpg Note:
Do not touch the white cable inside your printer.
Do not open the ink cartridge cover while the print head is moving. ink.13.7.8.jpg 4. Open the cartridge cover. ink.13.7.9.jpg 5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. ink.13.7.10.jpg Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) ink.13.7.11.jpg 7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. ink.13.7.12.jpg 8. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. ink.13.7.13.jpg 9. Insert the new cartridge into the holder and push it down until it clicks into place. ink.13.7.14.jpg 10. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. ink.13.7.15.jpg 11. Lower the scanner. ink.13.7.16.jpg 12. Press ink.13.7.17.jpg Start (NX210 Series) or OK (NX410 Series) to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. If you continue to see an ink replacement message on the LCD display screen, Press ink.13.7.18.jpg Start (NX210 Series) or OK (NX410 Series) and press down all the cartridges securely. Then press ink.13.7.19.jpg Start (NX210 Series) or OK (NX410 Series) again. Note:
If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. Caution:
Never turn off your Epson printer while ink is charging or you'll waste ink.
(Taken from the Epson online manual available here)
Oct 16, 2012 | Epson Stylus Multifunction Inkjet Printer/...
NX415 inkjet catridge refill
This is what I found on the Web. You can download the Manual if you like. Click on link below. Not able to put all here, do to limitation.
http://files.support.epson.com/htmldocs/nx415_/nx415_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Remove and Install Cartridges
Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones.Caution: not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1.
2.
If a cartridge is expended, you see a message on the printer’s LCD display screen. The icon on the screen indicates which color to replace. Press or OK (NX410 Series).
If you’re replacing a cartridge before you see a message on the printer’s LCD display screen, do one of the following:
to select Ink Cartridge Replacement, then press Start.
NX410 Series: Press Setup, press or to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
Apr 04, 2010 | Epson Stylus NX400 InkJet Printer
Scan without replacing print cartridges on Epson Stylus NX410?
You actually can scan documents when you dont have ink. Instead you will have to activate the scan function from the epson driver/program instead of pressing the scan button directly on the printer. I had the same problem and it took a while to figure out.
Feb 19, 2010 | Epson Office Equipment & Supplies
Sx415 I am unable to line up the printer head to
***hi there,il be willing to help you on that. ****
2. If a cartridge is expended, you see a message on the printer’s LCD display screen. The icon on the screen indicates which color to replace. Press Start (NX210 Series) or OK (NX410 Series).
***If you’re replacing a cartridge before you see a message on the printer’s LCD display screen, do one of the following:
NX210 Series: Hold down the Scan button as you press the Index Sheet button, then release the buttons. Press or to select Ink Cartridge Replacement, then press Start.
3. Open the scanner. Do not open the ink cartridge cover while the print head is moving.
Caution:
12. Press Start (NX210 Series) or OK (NX410 Series) to begin charging the ink. This takes about 2 minutes.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus NX410 won't print in Adobe Illustrator CS
Try to print your file in jpeg or tiff format.Good luck!
Jan 12, 2010 | Epson Office Equipment & Supplies
Epson printer
HOw do I clear a paper jam on my epsom dx 4450 printer
Apr 02, 2009 | Epson Office Equipment & Supplies
Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
323 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
