Question about Minolta XG-2 35mm SLR Camera
Where is the battery. Ineed to change it and don't want to open something that should not be opened and don't have a manual.
    Brigadier General:
  • 3,006 Answers
The battery chamber is on the underside of the camera next to the tripod mounting hole. Use a coin to unscrew it. The battery chamber holds two silver oxide SR44's; these are very commonly available still and relatively cheap, but you need to make sure that they are silver oxide SR44's and not lithium LR44's. LR44's are precisely the same shape and size, but have the wrong (lower and inconsistent) voltage. They won't damage your camera in the least but will cause inaccurate light meter readings.
Posted on Sep 29, 2010
Memory Card/Battery Compartment won't open
In General... You need to slide something first and then open the door. Please looks at your manual.
Jul 24, 2017 | Nikon Coolpix S30 Digital Camera White
I am locked out of garage. Liftmaster 1265 will not open.
Sounds like what you need acces too is inside the garage. If you don't have a pedestrian access door to your garage, or a window, or these are both locked, you are going to have to break something. Sorry to tell you that. Just pick the thing to break which is easiest to repair. Once inside, there is a mechanical release (usually a pull rope hanging from the opener main unit) that allows you to open the door manually. Then you can use the garage until you can address the problem. Good luck.
Oct 23, 2012 | liftmaster Chamberlain Garage Door Opener...
Yaris hatchback wont open
The remote may have a bad battery or the system has lost programming, refer to the owner's manual to change the battery in the remote and if that doesn't cure it the dealer must use a special tool to reprogram the system to the remote frequency. This solution is based on the fact that both the remotes don't work, the remote can be bad, this is esp true if it has been dropped.
Jul 27, 2012 | 2008 Toyota Yaris
Laptop buzzes after shutdown
F10 is compaq open setup restore defaults F10 save changes. If you get blue screen open task manager using ctrl-alt-del to get task manager/new task config ok. don't put anything in password. Good luck.
Dec 31, 2011 | Computers & Internet
Red sercurity light flashes in my truck
You could try re locking the doors then unlock them. Then open the hood and disconnect the negative terminal on the battery for 2 minutes. Hook up the battery and start the truck. This will flush the PCM's cache and restore everything to its normal state.
Dec 11, 2011 | 1999 Dodge Durango
Hello, Ineed to change the battery of the time and date. I want hnow the number of the battery to buy one and changing. Regards Josephine.
Sounds like you uwant to change your CMOS battery. You should bring this to a professional so as to not damage your computer. If you don't know what you are doing to will cause more damage than a worn out CMOS battery
Sep 13, 2009 | Compaq Presario Notebook
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
Changing digital combanation on safe
Manual for bunkerhill safe , how to program and specs:
http://www.harborfreight.com/manuals/93000-93999/93575.pdf
No Known default combination.. Sorry!
Nov 14, 2008 | Check Point Network Adapter
Minolta XG-2 35mm SLR Camera Logo
100 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
