Question about Dishwashers
I require info on how to use a heller hdw121ss dishwasher
Just moved into s property that has a heller DWH116 and it runs for 24 hours! Has this happened to you before? I read the manual and looked up online but I dont know what's wrong with it?
http://ernie.awa.com.au/Heller---Dishwasher/default.aspx u can find the manual here for it. in my opinion it sounds like a bad timer which can be changed but if it has quite a bit of age on it, then I would consider replacing the dishwasher itself.
May 21, 2016 | Hardware & Accessories
Heller dwh16 element is it easy to replace
Not really , you will need to take the draws out to replace it but it save $$ doing it yourself :)
Oct 29, 2013 | Fisher DS603W / DS603B / DS603I Dishwasher
Heller MIST40B instruction manual
I am assuming this is not a dishwasher but a mist fan.
Try contacting awa in Australia who support Heller brand products.
Ph:
1300 366 144
email:
warrantysupport@awa.com.au
Jan 05, 2013 | Dishwashers
Dishwasher error code
The manual shows there are 3 possible causes of the alarm
1. water supply is not there
2. drain time is too high - possibly a blockage in the kitchen sink drain
3. the water overfill in the base.
Most likely the cause could be 2 or 3. If kitchen drain is clear then the reason could be a faulty overfill switch at base of dishwasher assuming there is no water collected at the base where the motor and pumps are located.
Jan 04, 2013 | Dishwashers
My Heller HWD12 was working ok then wont start.No water seems to be going in.I have no manual.
We have the same problem....buying another make if we can t get a fix
Sep 01, 2010 | Dishwashers
Heller dishwasher error 004
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Sep 20, 2009 | Dishwashers
Heller DWH16 slimline dishwasher not filling with water properly has to keep being moved to try and get it to fill which sometimes succeeds bit not all the time
I have a heller dwh16 dishwasher - it appears to be in perfect working order but does not heat up with hot water/steam as it used to.... I think is may be the heating element which has burnt out - any ideas? thanks
Sep 21, 2008 | Dishwashers
Heller dishwasher fuses electrical circuit during cycle
May be a problem with the element or you may have a build up of water in the base of the dishwasher
Jul 11, 2008 | Dishwashers
My dishwasher model dwh3 manufactured by Heller is displaying error 3
my dishwasher has the same problem what is the solution?
Jun 29, 2008 | Maytag Dishwashers
DISHWASHER HELLER DWH3
my heller dish washer has a error code e4 ? where can i find what this means
Apr 27, 2008 | Maytag 24 in. MDBH970AWS Built-in...
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
