Question about XFX GeForce FX 5200 Graphic Card
OUT OF RANGE on monitor screen
I just bought the XFX GeForce FX 5200 graphic card. I installed it into the agp slot and turned on my computer. It recognized it. I installed the driver from the cd it came with. It prompted me to restart and so I did. After the Windows XP logo comes up, the monitor screen goes to black and says "OUT OF RANGE". But I can still hear the windows starting up. Please help.
  • AnneV1 May 26, 2008
    Thanks a lot..
  • 105 Answers
You have to change frequency of monitor to work smoothly form display property.
Out of Range is frequency is not matching
To solve this, wwhile booting Press F8 to get advanced boot menu from that select "Enable VGA mode"
change the display properties
right click on desktop - Select properties - Settings - Advanced (from bottom) - goto monitor tab - change the frequecny to default. and restart the system normal mode
Posted on May 25, 2008
3 Suggested Answers
kaimster
  • 87 Answers
SOURCE: HP DL 330 advantage of AGP graphic cards
the larger the size of the graphics card the better quality your gaming and entertainment programs will come out. however the graphics card cant always help if your monitor doesn't have a good enough display (480, 720, 1080p)
Posted on Jul 13, 2010
yecalam13
  • 41 Answers
SOURCE: HP GeForce FX 5200, AGP Graphic Card fit the slot
No this card won't work in an 'HP Pav. Slimline s3620f" The specs from HP say it has one open PCI-E slot that is used for graphics cards.
Posted on Jul 09, 2010
I am not able to install the card in my PC g31 gigabyte board nvidia geforce fx5500 256mb
G32 board has no agp slot ....
and the card you are using is AGP NVIDIA GE FORCE XFX 5500 ...
g31 has 16x pci slot so buy PCI card not AGP...
Dec 30, 2010 | XFX GeForce FX 5500 Graphic Card
Jul 13, 2010 | HP GeForce FX 5200, (128 MB) AGP Graphic...
Inserting GeFroce fx 5200 graphics card!
sorry to say this your dell system only has a X1 vga slot it is not compatible with the card you have.
If you want to use a card you have to go for a new system
Nov 30, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Nvidia v-vard
First, look at the card and make sure it's actually an Nvidia Geforce FX 5200. Of so, then you probably installed the wrong drivers for the card. Make sure you go to the Nvidia website and download the correct drivers for the card after deleting the ones already installed. Installing the incorrect drivers could cause Windows to report the wrong type of card is installed in your PC.
Let us know...
Apr 03, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
I have a Geforce Fx 5200 graphics card would like to up grade
the motherboard supports only APG graphic crads, as long as you can get AGP your are fine. there are several brands in the market. so i suggest you have a look at the link below.
1. http://www.ngohq.com/home.php?page=Articles&go=read&arc_id=116
Feb 25, 2009 | XFX GeForce FX 5200, Graphic Card
GeForce FX 5200, Graphics card not working
Follow these steps
In safe mode. Go to display properties > setting > advance > monitor > Refresh. Decrease refresh rate to 60 Hz. Apply setting and then restart windows.
Hope it works.
Mar 23, 2008 | XFX GeForce FX 5200, Graphic Card
Fx 5200 geforce graphic card
You did not mention if the board your running has an integrated video card on it. If it does & you have added the FX 5200 AGP you need to make a change in your bios. Set the bios to see AGP. Re-check the insertion of the AGP card. Remove the video card. Use a strong flash light & look into the AGP slot. Use canned air & blow out the AGP slot. Re-seat the video card evenly into the AGP slot. Try again.
Feb 13, 2008 | XFX GeForce FX 5200, Graphic Card
Dell 8600 and video card
You need to open up your pc tower and insert it into an open slot. Do this with the computer turned off and UNPLUGGED. Once installed, turn you computer on, but still plug monitor into your old video card. Assuming you're using XP or Vista? It should detect your new card and install the drivers automatically. If not, you need to install on your own. Use the CD that came with the card, if you got one. Or you can download the driver here:
http://www.softwarepatch.com/utilities/nvidia-geforce-fx-5200.html
Then turn off computer, plug monitor into new video card, then start computer.
Jan 12, 2008 | XFX GeForce FX 5200, Graphic Card
Installing GeForce 5200 on Dell Dimension 2400
I suggest that better check that graphic card in another machine and make sure it is working.
Also find out the data transfer speed of your mother board through the AGP slot is compatible with your graphic card. (e.g. 4X, 8X, etc.)
If you are sure that your system really has an 8X AGP port (A choclate colored slot) then you could deffinitely install the card and work with it.
With the information I received the Dell Dimension 2400 deos not features an AGP 8X port, in that case it is not possible to install the card.
Then you should buy a new motherboard with AGP 8X Port to be able to install the Ge force FX 5200.
Nov 03, 2007 | PNY Verto GeForce FX 5200, (256 MB) PCI...
GeForce FX 5500-picture flickers
assuming you have set your agp slot in the cmos settings to the primary graphics controller and already had the agp graphics slot driver installed for the motherboard, try using a driver from the nvidia web site if you are having trouble with the driver that came on the cd. Use the VGA onboard graphics if you have any or fit your old card and click on the link below for XP Drivers http://www.nvidia.com/object/winxp_2k_93.71.html If you still have problems then you will have to try an ATI graphics card as it just may not be compatable with your make of motherboard
May 08, 2007 | XFX GeForce FX 5200 Graphic Card
XFX GeForce FX 5200 Graphic Card Logo
1,337 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
