Question about Packard Bell GCD-R580B (gcdr580b) Internal 8x CD-ROM Drive
Cd door keeps onpening and closing
My cd door on my packerd bell computer just keeps opening and closing.... It wont stop.. the only time it stop is if i turn the computer off
  • 2 more comments
  • Anonymous May 27, 2008
    The Cd inserter for my computer will not stop opening and closing, it's driving me crazy, the only time it stops opening and closing is if I shutdown my computer's power. Help me.
  • AlphaDogg Jun 12, 2008
  • usca Nov 09, 2008
    cd door keeps onpening and closing problem
  • m82chat2 Nov 24, 2008
    I have the same problem with my Laptop which is a Packard Bell EasyNote
    Guru:
  • 859 Answers
When this happens it is usually one thing, but could be two.
The most common reason is that the button you use to open and close is stuck in the IN position. Turn the PC off with the drive door held open. Using a paperclip try to get behind the push button and press it outwards.
Second most common problem, the switch the button activates is worn and has failed in the depressed position.
Fortunately, replacement CDROM/DVDROM are rather inexpensive, but you would need a technically savy friend or relative to help you or you can ask your friendly neighborhood computer guru to help. Or, lastly, you can take this into a shop for a replacement as the newer drive will be better and faster than what you have now.
As always, if you have any need for clarification or further questions please do not hesitate to comment back to me.
Regards,
Worldvet
Posted on Jun 09, 2008
HOW DO I OPEN THE CD DRIVE
Hello. The stuck cd drive door. Bin there before. Use a paper clip, bend out one of the arms of the paper clip. Look for a tinny sized pin hole on the cd drive door. Use the paper clip as a push key. Put the paper clip leg in to the hole, lightly push in and pull the cd drive door lightly toward you. Then you can take out the cd and push to closed the door. Then you can use the computer as before. But remember to keep the paper clip as your emergency key. Good Luck.
Jun 03, 2014 | Packard Bell Computers & Internet
Sony dav-dz555k home theatre system-dvd tray keeps opening and closing, wont read disc at all. have to manually push tray closed and change setting from dvd to something else to stop it.
You seem to be having a door sensor problem. When the CD tray closes a small switch under the loading tray shorts telling the microprocessor the door is closed and to stop the motor (either way when it opens or when it closes). A malfunction in this switch causes this symptom.
Mar 14, 2011 | Sony Audio Players & Recorders
The ignition bell wont stop ringing
You need to unplug the door harness one at a time to locate which door is causing the problem. Once the door is located, you can replace the switch which is located on the lock mechanism.
Sep 29, 2009 | 1994 Ford Ranger Supercab
Packerd bell
your best bet is to go to the manufactures website and download the proper driver
Jul 22, 2009 | Toshiba Satellite A135 Notebook
Bell wont stop ringing
Thankyou,
Bonjour, dearest Sir/Madamme, it would be an honor to help you out, the bell is a door open and close alert system in the Elite. They are usually activated with time. On the hinges on the doors, there are sometimes tilt switches, the tell the circuit system when to alert, as soon as the door is open some count time, if the time is prolonged, and the switches are open, (that would mean the door is open as well). They activate. I would check the door hing, a swith could be open/closed depending on the format of operation.
Thankyou, :)
Jun 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Warning bell won't stop sounding
Sounds like your door sensors are going bad and are not relaying to the computer that the doors are fully closed, with that being said you will need to replace them and also at the same time it will stop the door locks from going crazy
May 16, 2009 | 2000 Ford Windstar
Cd/dvd door is opening and closeing all by it self
this is due to improper connection of wire from optical drive to motherboard i.e check whether the power cable/ide(sata)cable is not loose.Also clean their plugging area.problem will be solved.thanks.
Nov 23, 2008 | HP Pavilion a6544f Desktop PC
Cant get vista off my pakardbell i media x2414 i would like to put xp on it
Dear Sir.
In order to get xp on your computer.
You need to install windows xp by formating your computer by using the windows xp operating system cd.
If your computer comes vista installed on that you need to get xp cd from your packerd bell support.
http://www.packardbell.com/support.htm
Regards
MOhammed.
Jul 18, 2008 | Packard Bell Computers & Internet
Dvd rw
We need a few clarification questions answered before we can proceed. Okay?
What is the model of your Packerd Bell computer? In you desktop you can press simultaneously the Windows key and the Pause key and the information should be on this pop up window.
Also send us the version and SP number of the version of Windows you are using.
You've come to the right place as many of us here have previous experience with older computers such as yours.
Regards,
Worldvet
Jun 06, 2008 | Packard Bell GCD-R580B (gcdr580b) Internal...
Packard Bell GCD-R580B (gcdr580b) Internal 8x CD-ROM Drive Logo
364 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
