Question about Sony Playstation 3 (PS3) Console
PS3 either won't turn on, or freezes immediately. HELP!!!!
H Sony Bravia LCD TV which can support up to 1080i. I have, to my knowledge, correctly connected the PS3 with the TV using AV cables and an HDMI cable. Everything else has been correctly connected as well. Here's what happens when it doesn't turn on:
1) I flip the back switch On, and slide my finger over the front On sensor.
2) I hear the fans quickly, for only part of a second, start working, then suddenly shut down again, never coming back on for the rest of the session.
3) I notice that the HDD light near the USB ports are not on.
4) I notice that only the green light is On; this is on the PS3's front.
5) During all this, the screen is completely black, displaying no menu at all, and there is no audio.
Here's what happens when it does turn on:
1) I turn it on with the sensor
2) As usual, a little static comes on for the image(signaling that that session will turn on the PS3), and the PS3 menu starts to load. Fans go on, then immediately turn off.
3) The HDD light blinks a little and then is gone.
4) Following this, the screen will freeze in a matter of seconds or a few minutes. I cannot perform any updates.
5) I would then have to hold down the power button for 15 seconds to allow the system to turn off sustaining a solid red light. If it doesn't freeze, it turns off by itself, sustaining a flashing red light.
As a result of this, I cannot use the menu, play any games, or simply use the PS3.
If anyone knows of any possible solution for this seemingly impossible problem, please leave an answer.
Thanks
  • 24 more comments
  • d_marlon Jun 03, 2008
    I have the exact same symptoms. Did you find a fix?
  • carbonfreeze Jun 08, 2008
    When I swtich on my ps3 the menu freezes at a certain point every time
  • rushman40 Jun 12, 2008
    Same problem here today. mmmmmmmmm......
  • Anonymous Jul 20, 2008
    me 2
  • timimartins Jul 20, 2008
    same problem last night. ill try again. please send fix it solution. cheers.
  • czxm94 Jul 20, 2008
    I have the same problem and it also won't turn off when I hit the button as well.. STINKS
  • gcode Jul 20, 2008
    my system wont stay on. when i press the power button it will come on for 2 or 3 seconds, then the green light will turn yellowish and shut off with the red light flashing. i cant eject my game out of the system.
  • Anonymous Aug 02, 2008
    I just started having this same problem playing MGS4. Hopefully i dont have to spend 150 on sony to fix it.
  • SwtRina Aug 10, 2008
    Hi, I had My Ps3 for 6 months and all of sudden it won't come on I played it on line and it wouldn't exit from on line playing so I turned it off from the back of the console and now it won't come back on no green light not fan working nothing. Sony said give it a day or so it should come back on PLEASE HELP ME!!!!!!!!!!!
  • Anonymous Aug 10, 2008
    same
  • losrodriguez Aug 10, 2008
    wont turn on, try toclean the console
  • bysk Sep 18, 2008
    I first noticed the problem when I turned on the system and all that was on the screen were a bunch of dots and lines. I then reset my system to the standard composite AV output and had no picture or sound. My system is frying up around the power supply so I'm guessing that would be the issue. I've tried everything else that I can find on this site and it all leads to the same solution... Power supply. If anyone could give me some help on this it would be much appreciated. Thanks.
  • Anonymous Oct 17, 2008
    Same thing here. Any help would be appreciated.
  • young dc Dec 31, 2008
    when i turn on the system there is no audio and the tv sreen is all black and only the green light is on and that little orenge light is noton but when i turn own the system the little orenge light is blinking and then it turns off
  • Anonymous Feb 04, 2009
    Im so p***** off right now cos its just happened to me. I also read somewhere that you lose all your data if it does work again...I hope you dont cos I play games like Fallout 3, Littlebigplanet and MGS4 and I would rather lose my legs for the rest of my life than lose this data.
  • armando_4p Feb 14, 2009
    yes i have same exsact problem shitt this ******* sucksss if anybody can help please dooo
  • krzrican Feb 14, 2009
    playstation turns on then turns off quickly.
  • Anonymous Mar 18, 2009
    Exact same problem you have here.
  • joshyl Apr 03, 2009
    my warranty is up with my s3 and they have said if i want it fixed i will need to pay £145.00 which is disgraceful because it haened because of one of their updates
  • ps3helper Apr 17, 2009
    i turn my ps3 on and it just does the sound and the line going by and it doesent say to log in or nothing and then it goes dark and then blank how can i fix this
  • lemmomm Apr 18, 2009
    ours started freezing a few weeks ago... the fans would kick on for a minute or two cut off and it would freeze, we started putting a house fan on it and this seemed to help, now it will start to load the game and get into the main load screen and thats it, or it won't even get that far...
  • jasonatanner Apr 25, 2009
  • Anonymous May 05, 2009
    i turn on my ps3 and it freezes on the stran of lines and wont let me turn it off so i have to use the back
  • Anonymous May 14, 2009
    1)The game starts and then the menu pops up and freezes.
  • austin83 May 11, 2010
    PS3 is one of the most amazing gaming device but like other competitor
    gaming devices (Xbox and Wii) It also has some problems like Freezing
    up.. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up.
  • timimartins May 11, 2010
    i have the same exact problem. please can you send me the fix it guide. I tried to call sony but its not going thru or the number not in service. maybe its a major fault that needs to be reported to Sony. Same as their lithium batteries a while back.
    Champion:
  • 207 Answers
OK it sounds like a problem I had with one of the units that came into my shop, I do believe you will need a new part which means you will need to break the seal. I suggest you call sony and see what they say and what they will do for you. 1-800-345-SONY (7669)
If they want to charge you id say forget it and try it yourself.
i can send you a guide to help you fix it.
I am thinking a sensor board or a power supply could be others and its hard since its not in my face but let me know what sony says and letss fix this baby.
I do also buy broken ps3s and can help you find a steal on a used or new unit!
Posted on May 27, 2008
  • JaymeRN
    JaymeRN Jul 01, 2010
    Hi I have a problem with my sons PS3, he had it sitting on the floor and my youngest son threw a shoe at him and hit the PS3, his PS3 will not even turn on at all now, he has a game inside and can't even get the game out!! My email address is spoilgirl1972@yahoo.com please email me and tell me what is either wrong by chance or what to do. thank you Jayme
  • izzymayne Sep 07, 2010
    yo, i'm having this exact problem with my PS3.
    Holla at me man IzzyMayne@live.com
    The fans wont turn on and the screen is just black. Everythings connected correctly, need assistance.
Hold down the power button until u hear 3 audible beeps then the powerlight should b red hold the power button down again until u hear 2 audible beeps then a double beep then let go the restore menu should appear choose option 3 restore hdd click ok this restore will clear all corrupt files on the hdd it will automatically restore up to 3 times if this doesnt work u need to contact sony good luck
Posted on Apr 04, 2011
If you have mgs4 there is a problem with all of them i think you should ring the makers of mgs4 if you have it
Posted on Jul 31, 2008
Can you email me the fix it guide?
Posted on Jun 02, 2008
Me 2
Posted on Dec 23, 2009
You punks think this is a joke. this jhju guy is a punk. how can u be sending xbox360 info for PS3 they arent even the same makers talk even of the same kind of console. dont make me laugh. Please give me something I can work with else its a brand new PS3 for me... and a wii
Posted on Oct 14, 2008
2 Suggested Answers
  • 17 Answers
SOURCE: PS3 Problem HELP!!!!!!!!!!!!!!!
maybe its on the wrong chanel????
Sony Bravia LCD tv model KDL40S4100 won't hold settings.
What you've heard is right. This is a main system control memory IC fault itself.
Jun 19, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Ps3 only displays in 1080i
I have similar problem , ps3 320gb + 5 years old sony bravia 1080p = everything OK
but when i connect ps3 to new samsung ue46d7000 1080p = doesn't work (only 1080i)
I am using same HDMI cable
Jun 19, 2012 | Sony Playstation 3 (PS3) Console
No signal. It keeps saying invalid format. I have tried changing the tv format to 1080i, 480p from the cable box and still won't get the right format.
We are here to do the best we can to help, we only ask that you do not forget to rate us before you
leave.
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
please do the follwing above,
best of luck to you,
Rulds2008
Aug 17, 2011 | Sony Playstation 3 (PS3) Console
I have a Sony Bravia kdl-32s2020 LCD with MPEG-2 DBV-T. Are there any possibility to upgrade them to DVB-C MPEG-4. This model is also HD-ready. Haw can convert them to FULL-HD (changing SD receiver with...
This tv have the capabillity for the Full HD max resolution 1080i or 1080p.The problems u have is not the tv capabilities.The tv incomming broadcasting signals are vary like DTV,SD,480i,720i low end HD.Max HD resolutions are 1080p or 1080i.
Dec 01, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a Sony Bravia TV I cannot get display off screen AV5 arrow 5 1080i/50 Stephen
you can turn off the on screen display by just pressing the button i+ on your remote control
Nov 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
PS3 and Sony Bravia
one of your lasers in PS3 is probably bad
Jul 27, 2009 | Sony PlayStation® 3 (80GB) Console
PS3 wont go 1080i/720p
I don't think there is a way to set your resolution manually, bro. They do it all by auto. If I may make a suggestion... Turn off both the TV & PS3. Unplug your HDMI, then make sure both your TV & PS3 are turned ON. Now re-connect your HDMI. A TV tech once told me that these units "communicate" through the HDMI. This can only occure whilst they're up & running. This may help get you going on to 1080i.
p.s. PS3 games only output 720p, max! This isn't always the case for Blu Ray movies, but it is for games. Good luck!
May 23, 2009 | Sony PlayStation® 3 (60 GB) Console
Blurry Text
you'll im afraid have to go the newer tv. the older models dont have the capacity to keep up with the high def out put of a ps3. id personally recommend a bravia, or vivo as i have not had a problem with either, since ive worked 9and played0 with them. please leave rating
Dec 08, 2008 | Sony Playstation 3 (PS3) Console
Sony bravia won''t play PS3
Try setting the resolution to a higher grade or a lower grade.. That solved the problem for me.. good luck!
Nov 24, 2008 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony Playstation 3 (PS3) Console Logo
11,447 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
