Question about Acer Computers & Internet
I need a replacement power cord for my Acer AL1912 LCD monitor.
SOURCE: Acer AL1912 Monitor Looping
I have fixed many of the al1912 easy fix
the problem is always corrosion on the circuit board that has the buttons
disassemble the flat panel remove 3 screws that hold button board on
disconnect the tiny cable from the button board
use a tooth pick and clean inbetween the solder connections where the ribbin cable plugs into button board
Posted on Feb 18, 2008
SOURCE: Acer AL1912 19" LCD Monitor goes black after power up.
The problem with this monitor is a leaking capacitor on the power supply board. It is the middle one at the top in a row of three. The value is 10V 1000uf. Common problem for these.
Remove 4 screws from back of display. The case can be popped apart with a small flat putty knife at different points along the two seams. Three latches on each side and two at top and bottom. Push and twist at the latch points. There is a metal cover over the two boards. Power supply board to left. Screws and plugs can be romved. Unsolder Capacitor and replace. Radio Shack probably has them. Maybe a couple bucks. Be sure the power has been off for a while. These also have problems with the button board and corrosion at ribbon cable.
Posted on Feb 28, 2008
ditto here, hopefully someone will have a solution
Posted on Jul 20, 2008
freetek
  • 5568 Answers
SOURCE: My acer AL1912 monitor keeps going fuzzy. It kind
An unusual problem for a flat screen monitor.
I suggest you connect the monitor to another PC to see if the problem persists since it could also be caused by the video card (or circuit, if on board).
Check your cables making sure they are solidly connected and wiggle them to see if you can cause the problem to come or go away; this would crudely check the shielding of them.
This kind of aberration could easily happen with a conventional CRT monitor if power supply filtering was failing but as mentioned, uncommon in a monitor that is essentially digital.
Posted on May 12, 2009
  • 3940 Answers
SOURCE: Any Drivers for ACER AL1912
With very few exceptions, LCD monitors do not require a driver. Almost always, and display setting issue is an issue with the Display adapter (Video Card) driver. The plug and Play monitor driver that is native to Windows should work just fine.
Posted on Jun 13, 2009
I use Acer AL1912 19inch (black) monitor. It is working properly for weeks. but sometime it suddenly go dark during work, although its light remains green. Now the only solution is to unplug its power...
Sounds like the monitor is dying, if it starts to die more and more often you will likely have to replace your monitor before it goes completely out. There are not many ways for a user to repair a monitor, unless the problem is with the computer, which you could test by connecting a different monitor to the computer for a while (if available). Hope this helps!
Mar 15, 2011 | Acer AL1912 19" LCD Monitor
How can I connect my Fujitsu Siemens key board with my Acer AL1912 monitor? There is a connect button on the key board, but where is the connect button on the Acer?
Is it a wireless keyboard? If that is the case, then you should have a receiver unit attached to the PC, usually to a USB port. The ACER is justt a monitor, here is the user manual: http://www.retrevo.com/support/Acer-AL1912-Monitors-manual/id/719ag115/t/2/
Jan 20, 2010 | Acer AL1912 19" LCD Monitor
With the screen connected to the pc (which is running and putting out a signal) hold a bright light to the front of the lcd - a led flashlight works well. Do you see an image? If so then circuitry driving the inverter backlights may be at fault. I had this happen with a Dell Flat Screen, and found one of a pair of transistors which drives the backlight had developed a short.
Aug 01, 2009 | Acer AL1912 19" LCD Monitor
Jun 13, 2009 | Acer AL1912 19" LCD Monitor
May 12, 2009 | Acer AL1912 19" LCD Monitor
I have a acer al1912 faulty
It might be worth a try but the two different sizes could have differing resolutions and if they do, the boards are not likely interchangeable.
Jan 29, 2009 | Acer AL1912 19" LCD Monitor
No display
Your minitors power supply is now damaged, probably from the power outage. I t will need to be repaired or replaced. Check the cost and benifits of both options and make a discision.
NSSMS
Jul 30, 2008 | Acer AL1912 19" LCD Monitor
Acer al1912 with S3inc trio 32/64 card
start with a 1024x788 60hz refresh , connect lcd
and then try any higher freq/refresh as it will ask you to verify.
Nov 02, 2007 | Acer AL1912 19" LCD Monitor
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
