Question about Nikon COOLPIX L20 Digital Camera
My camera shows that battery is low even if battery is new
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 29 Answers
Use Knowledge of Digital Camera Battery
A new digital camera rechargeable battery,the battery power generally is very low or no power consumption,and should be charged before use. Fully charged battery will be very hot, should be loaded into the camera after cooled.
When using a digital camera you should save battery consumption as much as possible. First, avoid using unnecessary zoom operation, if it is in zoom, it is recommended to move the camera position to get the same zoom effect. Second is to avoid frequent use of flash, flash is power, best not to use unless absolutely necessary. What is best to use the viewfinder when adjusting image, but do not use the LCD screen. LCD display amazing energy, so the best not use, because the ordinary shooting through the viewfinder can be completed. Of course, no need to block it in order to save power, such as when shooting at close range LCD display is an indispensable component. Finally, remember that when not using a digital camera,turn it off.
When using the digital camera battery for some time, the battery need the necessary clean. Many people may focus only on digital camera lens and body clean, but never thought the battery should be cleaned. To avoid power loss problems, be sure to keep the internal battery cover and battery contact points at both ends clean. If necessary, use a soft, clean cloth and gently wipe dry.Must not use or chemical cleaning of a cleaning agent such as a solubility.
In the process of digital camera battery,pay attention to using the correct method to charge digital camera battery. Best to use the original digital camera battery charger, which will help extend battery life. The charging time depends on the charger and battery,the use of voltage stability and the other factors. If this is the first use the battery (or batteries for months not used),remember, lithium battery charging time must be more than 6 hours, Ni-MH battery must be more than 14 hours, otherwise, will be shorter battery life .
If there is residual power digital camera battery, try not to repeat the charge to ensure battery life. If you use a nickel-cadmium battery, and stop charging after a short time, and then recharge it, doing so the battery can not be filled. This is what they called "memory effect", this effect would reduce the overall battery capacity and using time. Over time, less and less stored charge, the battery will also use the faster and faster.
If you plan a long time do not use digital camera, digital camera battery must be taken out from the digital camera or battery charger, and completely discharged, and then stored in a dry, cool environment, The battery should not store with the general metal objects. For a long time stored in the digital camera or battery charger may leak and cause damage.
If you need Nikon digital camera batteries replacement :
http://www.sales-battery.com/digital-camera-batteries/nikon.htm
Posted on Dec 09, 2010
  • 11,896 Answers
Clean the battery terminal connections with rubbing alcohol and a cotton swab
Posted on Sep 29, 2010
Always lowbat
Replace the battery if, even after you charge it, it shows Low Battery. If it is a new battery, your battery contacts in the camera may be faulty, or something in the camera may be faulty. I am sure it is just a bad battery though.
Mar 08, 2011 | Olympus FE-170 Digital Camera
Shows low battery, even after installing new batteries. will not work.
The best batteries are rechargeable NiMh batteries of the ENELOOP (Sanyo) type.
These batteries have a very, very low discharge. Some other brands have such types too.
Oct 21, 2010 | Konica Minolta DiMAGE S414 Digital Camera
Low battery
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
May 20, 2010 | Kodak EasyShare DX6340 Zoom Digital Camera
Low Battery Light Even with Brand New Lithium Batteries
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
Jun 18, 2009 | Samsung Digimax D53 Digital Camera
My canon A710IS shows the battery low light after a couple of minutes when it has new batteries in it.
1. use alkaline batteries or rechargeable NiMH batteries
2. you may need to clean and adjust the springs inside the battery compartment
more details please refer this
Why my camera keeps saying ‘change battery’ even with new batteries?
May 08, 2009 | Canon PowerShot A710 IS Digital Camera
Camera shows low Battery and goes off even if u insert a new one
are you using NiMh rechargeable batteries?
If yes, check that they are fully charged. If that doesn't do the trick, sounds like it might be a power circuit issue. Samsung is in Secaucus, NJ
or SamsungUSA on the web
Apr 15, 2009 | Samsung Digimax A6 Digital Camera
Showing low battery even when new batteries have been put in
Have checked and its still in warranty, thank you for replying Mags
Mar 30, 2009 | Cameras
Whenever i am trying to take photos it's showing battery is low.
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Mar 27, 2009 | Canon PowerShot A590 IS Digital Camera
How do u charge battery
well u can't "charge your battery", you have to put new ones in
Sep 09, 2007 | Vivitar ViviCam 3785 Digital Camera
Nikon COOLPIX L20 Digital Camera Logo
251 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
