Question about Nintendo Wii Remote Controller
We have bougt a new controller how do we get it to work with the wii home console do we press two buttons together to get it to work? Can you help thanks
    Problem Solver:
  • 5 Answers
Lots of people have this problem including me, what you do is turn the Wii on,( turn off other Wii remotes once done turning on Wii system), press the connect button on the Wii remote 1st before pressing the SYNC button on the Wii system. If the Wii remote you are talking about is like the classical N64 remote then i cannot help you at the moment but there should be a manual that tells you how to connect it. I can do some research for you if none of the following work.
Posted on Sep 29, 2010
My remotes were synced to another wii how do I re-sync them?
Step by step instructions on how to sync the Wii Remote or Wii Remote Plus to the Wii console using Standard Mode.
Note:
Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
What to Do:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. If you are using a Wii mini, the sync button is located left hand side next to the battery compartment. The sync button is a darker shade of red than the console.
  3. Remove the battery cover on the back of the Wii Remote to be synced.
    • Some models of the Wii Remote include a hole in the battery cover and a tool on the wrist strap to push the SYNC Button with. With this model, the battery cover does not need to be removed to access the SYNC button.
  4. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the Wii console.
  5. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  6. This sync procedure must be followed for each additional Wii Remote added to the system.
May 19, 2014 | Nintendo Wii Console
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
Help
go to the Wii home, press the Sync button and hold it, without letting go press the Sync button on the Wii control blue lights on the remote should start blinking let go of both Sync buttons and there, your Wii Remote Controller should be now working,
Apr 10, 2010 | Nintendo Wii Console
Controllers wont sync
If you have pressed the sync button on wii, then on the wii-mote, and it still didn't sync, try unplugging the Wii console for few minutes and try the process again.
There is another syncing mode, but you have to have at least one wii-mote connected to the wii. You press the home button and the click on the wii-mote on the screen. There will be a reconnect button. Press that and then press both the 1 and 2 buttons on the wii-mote[s] you want to connect. This is the ONE TIME ONLY connect mode, used when playin on a friends Wii. Once the Wii is powered off, the wii-mote wont be connected any longer and will still be the default wii-mote for your wii system [not on your friends]. Hope this helps.
May 10, 2009 | Nintendo Wii Console
Second wii controller is ot working on FIFA 09
press home button then go 2 wii remote settings then click on where the battery power is then you can sync your controllers
Jan 23, 2009 | Nintendo Fifa 09 for Wii
Cant add a controller
I had the same problem and called Nintendo support. They had us unplug the wii console for 30 seconds, plug it back in and start the system back up. BEFORE pressing the A button on the health and safety screen, we needed to take the battery cover off of one remote, press the red sync button, then quickly press the sync button on the front of the wii console (in the front - you have to open the flap). Once the single blue light was on at the bottom of the remote, do the same with the other remote (press the sync button on it and then on the wii console). Then the second blue light should be lit on the second remote. Hope that helps!
Nov 29, 2008 | Nintendo Mario Kart (Wii) for Wii
Cannot get the nintendo wii controllers to work
HAVE YOU TRIED PRESSING THE RED BUTTON ON WII CONSOLE AND THE A AND B BUTTONS TOGETHER AT THE SAME TIME TO GET THE BLUE LIGHT LIT UP ON THE CONTROLLER?
Sep 28, 2008 | Nintendo Video Game Consoles & Games
We have recently moved home and our nintendo wii remotes have stopped working. i have checked all the connections and have put new batteries in them
Make sure the Wii is plugged in correctly and the light on the power button is on.
open the small panel in the front of the Wii and open the battery panel at the bottom of the Wii remote
and press the red buttons together
If you had been suffering from batteries lasting a little while then Nintendo will replace the controller for free
Jul 08, 2008 | Nintendo Wii Console
2nd wii remote will not connect with mario play 8
We had this same problem so I did a google search for 2nd wii remote not connecting or staying connected and this is what we came up with and did this and it really works! So hopefully this will help all of you to. Good luck! K and M
This is from www.nintendo.com/wii :
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture below).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Dec 23, 2007 | Nintendo Wii Console
Wii black screen
The following fix should help users who do have problems with some virtual console games for the Nintendo Wii that display only a black screen after starting them while the sound remains normal. This does not work in all occasions but should work if you get the Wii menu when you press Home and works only for games that received an update for the interlaced mode.
Try out the following to see if this fixes the issue. Start the game normally until you see the black screen. Connect the Nunchuck to the Wiimote and press Home to see the menu options. Now press A + 2 + Z together which should result in a short “ping-like” sound.
This should have activated the interlaced mode. Leave the menu and you should see the normal game screen and not the black screen anymore. To change the mode again press A + 1 + Z using the same method as above
Nov 20, 2007 | Nintendo Wii Console
Nintendo Wii Remote Controller Logo
80 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
