Question about Linksys EPSX3 EtherFast 3-Port 10/100 PrintServer (Retail) (NTPRLSEPSX3L) Print Server
Looking for a Windows 7 driver for a Linksys Etherfast model number EPSX3 3 port print server.
  • butch869 Sep 30, 2010
    Nice scam you got here. Pretend that you provide free advice and then pull the old 'bait and switch' routine by giving no advice but instead offer advice on a pay only basis. Sometimes I wish I had the balls to be so unscrupulous, then maybe I'd have enough money to just buy a new print server instead of having to be victimized by people like you.
4 Suggested Answers
govinda123
  • 2260 Answers
SOURCE: Linksys Etherfast Printserver model no EPSX3
HI,
You will need to check the settings of the print server.
are trying to run the set up disc of the print server.
You can try to install the print server manually.
Click Here for more information
Posted on Oct 07, 2009
aokcmpter
  • 5 Answers
SOURCE: WPSM54G linksys printer server software does not
win 7 has some problems with networking equipment. there is a method for installing the wpsm54 on vista and win 7. go to this link it has a good clear set of directions. good luck, aokcomputer
http://www.ehow.com/how_5396340_set-vista-vista-windows-linux.html
Posted on Jul 23, 2010
  • 84 Answers
SOURCE: I have a wpsm54g successfully connected to my
Hi, the drivers on the Cisco website may help your friend. You can get them here: http://goo.gl/f2esj Hope that helps.
Posted on Mar 07, 2011
What is the password of epsx3 emulator
Go to Linksys, customer services for answers to these questions. (now Cisco). The answer could be also printed on the device tags, labels, or other attachments.
May 10, 2014 | Linksys EPSX3 EtherFast 3-Port 10/100...
Serial number for epsxe3 emulator intallation
The ver # (not serial #) will be on the label either on the bottom or back of the unit. expressed as either v. or ver .
Here's a link to the manual.
Do a factory reset, then install like a new unit. http://downloads.linksys.com/downloads/userguide/1224638357428/epsx3_ppsx1_ug_0.pdf
Mar 13, 2014 | Linksys EPSX3 EtherFast 3-Port 10/100...
WPSM54G linksys printer server software does not install on windows 7. Need a driver.
Jul 23, 2010 | Linksys WPSM54G Print Server
Is wps54g wireless print router compatible with windows 7: how do I get it installed
Contrary to the on-line advice that I have found, the Linksys wireless print server WPS54G is compatible with Windows 7. It is the installation program that is not compatible. While not as bad as the early days of setting hardware dip switches, the print server must be installed manually. Following are the many steps that I took to install my WPS54G to work with Windows 7; lengthy, but worth it.
1. Connect your printer to the PC using a USB cable and USB port. Allow the printer to install. Print a test page. Even though you just installed the printer, check for an updated printer driver at the manufacturer's website. I did this late in the process before I could get the printer to work. It installed an HP universal driver.
2. Set the printer as the default.
3. If you do not know the IP address of your print server, access the router using your browser. See your manual for instructions. For a Linksys, type the default IP router address 192.168.1.1 into the browser address bar. If you have done this in the past, set up your router security. The default user name is left blank and the default password is admin.
4. Connect your print server to the PC using a USB cable and USB port.
5. On the router locate the DHCP Client Table and determine the IP address of the print server. You might have to refresh the table. The default is probably 192.168.1.78.
6. Access the print server using your browser and the IP address of the print server. The default user name is left blank and the default password is admin. Set up security to match the router, SSID, password, type of encryption, etc.
7. Go to "Devices and Printers" (from the start menu), on the default printer icon that you just installed, right click and open "Printer Properties." Click on the "Ports" tab.
8. Click on "Add Port." Select "Standard TCP/IP Port" and click on "New Port." Click "Next." Add the IP address of the print server (probably 192, 168.1.78) and call the port whatever you want. Click "Next."
9. After the port configures and you get the "Port Settings" tab (you can also get there by clicking on "Configure Port), change the protocol to "LPR" and click "LPS byte counting enabled." Use "p1" or P2" etc. for the "queue name."
10. Disconnect the print server from the USB port and let it sit for 30 seconds.
11. Disconnect the printer from the USB port.
Apr 06, 2010 | Linksys Wireless-G WPS54G Print Server
EtherFast Print Server manual
Other gurus might correct me, but I don't think this can easily be done. You are dealing with "parallel" data with the HP and "serial" data with the PC. If your HP has cards you can change, then conversion to serial data is relatively simple, otherwise...
Mar 29, 2010 | Linksys EtherFast 10/100 (epsx3/uk) Print...
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
Linksys Etherfast Printserver model no EPSX3 getting error Print Server Failed, can you tell me how to fix it or why it's happening?
HI,
Oct 06, 2009 | Linksys EtherFast PrintServer Print Server
Linksys print server Model EPSX3
Firmware upgrade for your print server could fix your problem or kill your print server.
Try this first: SET UP A STANDARD TCP/IP port.
Set a static ip on the print server. Use that ip address to set up your STANDARD TCP/IP PORT. You can do this on the printers and faxes page.
Right click the default printer then click properties. You have to ADD A NEW PORT.
Good Day
Nov 05, 2007 | Linksys EtherFast 10/100 (epsx3/uk) Print...
Computers & Internet Logo
682 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
