Question about Konica Minolta DiALTA Di200 Copier
What is it when display reads malfunction code C2654 on a Konica 351 copier?
  • 1,110 Answers
C2654 code means Black Imaging Unit eeprom access error.
A condition of "EEPROM is not connected" or
"There is an access error" is detected in
EEPROM of the Imaging Unit.
So the issue lies within your Black Imaging Unit. I would try sliding the imaging unit out partially, then re-installing. Reset by switching off the main power.
If this does not solve the error then you will need to call your local service provider.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Sep 29, 2010
Konica minolta bizhub 163 error 0045, what I do to work
from what I've read here:
Error Codes Konica Minolta bizhub 163
, this is a Fusing Cooling Fan Motor malfunction, which suggests, I'm afraid, that you have to have it serviced.
Kind regards,
Jon Erik
Nov 14, 2014 | Konica Minolta bizhub Office Equipment &...
Malfunction c3451 detected for bizhub 250 konica minolta
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Read More...
Error Message C3451 and Printer Support and Konica Printer Support
Jul 23, 2014 | Office Equipment & Supplies
Konica Minolta biz hub c550 error code c-EEE3 Help please
To reset the malfunction code press follow keys:
Turn OFF the copier,press and hold pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message on the display and release the Utility key.Touch the message and turn OFF the copier.Wait 1 minutes and turn ON.Good luck.
Mar 21, 2013 | Konica Minolta Office Equipment & Supplies
Solution for konica 351 erer code c-0098
fuser drive error. check the pressure/retraction gear on the fuser.
Jan 18, 2013 | Konica Minolta bizhub Office Equipment &...
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
Fatal Error 21H
FATAL ERROR CODE 21H / SERVICE CALL 21 TRANS DET SENS: Malfunction of the OHP detecting sensor
check the OHP detecting sensor (PC3A) (it's at the front above the waste toner sensor pc6)
May 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica 8031 Malfunction Code C-0990
http://www.pressa.net/info/?id=34
This page says, that this code is displayed on "Main tray up problem".
I suppose they didn't change the codes that much, so its possible that you can work with this one...
Apr 02, 2008 | Konica Office Equipment & Supplies
I am having problem with my konica minolta Bizhub C-450 malfunction C-2257
Dear,
Let us know , what Code is display on your Minolta C450P. So that we can provide you the proper solution.
Takecare
Mar 17, 2008 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta DiALTA Di200 Copier Logo
710 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
