Question about Whirlpool Washing Machines
Top load Whirlpool Washer with failing lid switch. Spins if I push down on switch with screwdriver. Seems to be a worn or damaged switch, but can't determine which screws/fasteners to remove to be able to lift up top of machine to access/replace the switch. I can't find the instructions on this unit. Can you provide that portion of the manual or in general? I don't know the model number. It is my daughter's machine adn my granson is keeping it busy. GB
    President:
  • 1,430 Answers
Try this link replacing a lid switch
Posted on Sep 29, 2010
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
Washer will not spin dry
see the causes:
t doesn't pump or spin
frozen pulley or broken belt replace+lid switch open or defective replace
It pumps, but doesn't spin
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, the basket is worn.
It spins only with the lid closed
for safety, only sping with the lid closed.
Jun 19, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't spin during rinse cycle. agitates fine during was cycle.
The lid switch is probably your culprit. the washer won't spin or drain if the lid switch is defective. Try pushing down on it with a pen or small screwdriver and see if it will spin then. There should be a slight clicking nois when it is activated, although it will sometimes click even though it is not working.
Nov 15, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer stopping mid-cycle
Push down on lid. You may have a bad lid switch. Start machine and press the switch down with something like a screwdriver and see if the motor runs.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Shuts off in between rinse and spin cycle
check the lid switch. if it's loose, worn or broken washer won't drain/spin. try pushing down on the lid when it's stopped. switch is either on the right side visible with a small hole that a plastic activator on the lid itself or on some activated by the left hand rear hinge under the top and need the hinge tightened only..
May 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Nothing happens after filling up
The missing pinis more than likely your problem.
Take a pencil or small screwdriver and insert into the lid switch hole and try the washer.
If it works, replace the lid pin.
If not, replace the lid pin AND the lid switch.
Apr 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top load belt driven commercial --spins while agitating
tobe a belt driven wp it would have tobe pretty old,if so its down in the cam bar area.the feet or plungers break and the cam bar dose not pull back.i would remove cam bar and file to clean up or replace if to worn along with new plunger.also use lite greese on cam bar where it slides and on bottem of blungers.also check the condition of your wig wag[control magnet.May God bless your house,tom
Jan 02, 2009 | Whirlpool GSC9455 Top Load Washer
Whirlpool WTW5300 SQ Water leaking...Help!!
The water pump is the front and has probably failed.
REMOVE POWER
To access the pump, lift the console by one of three ways.
1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
3. Insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white or gray in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The pump is mounted to the motor with two spring clips. Look at the face of the pump for any signs of melting or blistering. (grey bubbling)
Jun 15, 2008 | Whirlpool WTW5300SQ Top Load Washer
Whirlpool washing machine model lsq8243h
The lid switch has failed.
To access it REMOVE POWER, lift the console by one of three ways. 1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward. 2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw. 3. insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
The lid switch is attached to the cabinet.
Jun 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool AWZ412 wont spin seems to do everything else have tried with an empty machine but still no spin
The first thing to fail on a washer is the lid safety switch. It's right under the top, a little tab on the lid pushes it. Lift the top, check the switch. To test it: temporarily connect the two wires to it together. If the machine spins, replace the switch.
Apr 02, 2008 | Washing Machines
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
