Question about Tek Nek Toys Toys
The lights on the propeller for the Elmo Airplane aren't working anymore. Is there a way to fix this problem? All the other lights and sounds work.
3 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
Posted on May 30, 2009
bronk50
  • 27725 Answers
SOURCE: My speakers just for some
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
if you don't have the drivers you will need to download them
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10005159.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-sound-blaster-audigy/3000-2120_4-10198811.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
Posted on Jun 30, 2011
Why won't my 22 in. Kohler Low Wheel Variable Speed Self-Propelled Gas Lawn Mower self propel anymore?
i would guess that the belt is'nt tight enough when engaged. when you press the drive bar on the handle it should make the belt really tight if not it will need replaced. sometimes the gears in the wheels will mess up. there are videos on you tube that describe that and also the belt.
Apr 22, 2017 | Garden
My Frigidaire FWT645RHSO front load washer sounds like a propeller airplane when it spins...HELP!
Robin, it sounds like the tub bearings may be going out on your machine. With the washer empty, reach inside at the top and gently lift the inner stainless steel tub. Does it move up and feel like there is some slop or play in the tub. If the bearings are tight, the inner tub will not move much at all independently of the complete outer tub assembly.
Have you noticed any grease on any clothes recently? Usually what happens is the water seal fails and the water eventually washes the grease out of the bearings and they fail.
Depending on your skill level, there are some good online blogs about tub bearing replacement. You may not want to deal with it. You have to make the call on that. Thats my 2 cents worth. Good luck.
Mar 19, 2014 | Frigidaire Washing Machines
Dragon voice stopped working yesterday-suggestions?
hello, I also meet this error about my iphone, I get many help from this forum, and also bought many DIY repair tools from china supplier, and vipprogrammer help me fix this error. maybe you can try it. or contact they WhatsApp:+ 8615986801289
Link: http://www.vipprogrammer.com.
hope can help you!
Aug 27, 2017 | Apple iPhone Cell Phones
My Elmo TT-02RX document camera is not working properly. The blue power light does not stop flashing when I turn it on, and I am unable to use the camera or switch over to projecting what is on my...
Your Elmo TT-02rx comes with a five year manufacturers warranty. Contact Elmo at 1-800-947-ELMO and they will instruct you as to how to trouble shoot your doc camera or send it in for warranty service.
Apr 14, 2011 | Elmo Projectors ELMO TT02RX DIGITAL...
Hokey Pokey Elmo sings and moves his hand and foot but stopped shaking and won't turn around in a circle. It worked fine then stopped working we changed the batteries and it worked a short time then quit...
Hi ms_debbie13
    How to Activate
  1. This plush, shiny red Elmo is standing with his arms up above his head. One foot is lifted slightly off the floor and the other is on the floor. On that foot, there is a swivel allowing Elmo to turn, the battery door and the on/off switch. Turn Elmo on and stand him upright then squeeze his left hand to begin his song.
    Elmo really moves his right arm and leg in time with the song, and also turns in a circle. When the song is done Elmo says, "Whew.. that was fun! Elmo's pooped!"
  2. Alternative Mode
  3. The alternative mode is Elmo trying to keep up as the music keeps getting faster. If Elmo falls over he will say, "Woops!" and then he will thank you when you set him back upright.
Jan 30, 2011 | Toys
MY CESSNA IS NOT TAKING OFF. IT ALWAYS GOES TO HIT THE GROUND, I SPENT A LOT OF MONEY AND NERVER SUCCEDED WHEN TRY TO FLY. COULD IT BE A PROPELLER PROBLEM?
Check the flight controls. Does the elevator works? if it does. then problem is on thrust. check the propeller speed, does it have enough power? Don't forget to check on the powerplant (battery or engine). But judging from your story, it is the flight control problem. cheers.
Oct 24, 2010 | RC Cessna 747 Airplane 4 Channel Electric...
I dont recive messages my signal bar is gray insted of white please help
try this steps if it will work
  1. From the standby screen, press the right soft key for Menu
  2. Select Settings (9)
  3. Select Phone (4)
  4. Select Airplane Mode (6)
  5. Highlight either On or Off, using the navigation keys
  6. Press the left soft key for Select to save the Airplane Mode setting
Mar 19, 2010 | Samsung Propel A767 Cell Phone
Elmo will not turn on, batteries are new
THE SENSOR IN HIM HAS MOVED.FEEL AROUND FOR IT THEN PUSH IT BACK INTO PLACE
Jul 15, 2009 | Gund Sesame Street: Elmo 25" Plush Doll by
ELMO document camera only shows documents in black and white, not color. Is there something wrong with the bulb? the camera?
My ELMO unexpectedly stops working during class. The blue power light is still lit but the ELMO is not recognized through my projector.
Any suggestions on what the problem may be?
Mar 25, 2009 | Elmo Projectors EV-200 Slide Projector
Toys Logo
Top Tek Nek Toys Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Tek Nek Toys Toy Expert? Answer questions, earn points and help others
