Question about Microwave Ovens
My Champion juicer modelG5NG853S has two cracked plastic pieces to the grinding assembly that I need to replace A: the 5" diameter funnel spill shield that fits atop the plastic grinding shield B: the 3" X 4" square box wall that slides onto the grinding assembly on two tracks....and holds the screen in place against the assembly.... need replace both
  • 11,896 Answers
Www.championjuicer.com/
or
www.harvestessentials.com
ww.productsforhealth.com/Champion.htm
Posted on Sep 29, 2010
Sharp r520kst door wont stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Mar 23, 2013 | Sharp R-520KST Countertop Microwave Oven...
Convection microwave turntable does not turn. Makes a clicking noise.
Try removing the turntable plate, and then lift up on the roller assembly that the plate sits on. These roller assemblies are usually made of plastic, and often times the center "axle" (the part that goes down into the hole in the bottom of the microwave) breaks or cracks. If it looks like this piece is cracked or broken, just take it down to an appliance repair store (or just write down the model # of your microwave and bring it with you). Replace the roller assembly, and you're good to go.
You can also find these roller assemblies online pretty easily as well, and they're usually under $10 USD.
Good Luck.
Aug 25, 2009 | Sharp Microwave Ovens
I need to replace the handle. Can you give step by step help?
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 07, 2009 | GE JVM1650 1000 Watts Microwave Oven
Goldstar 1310W built in
The following parts are in the turntable system: The turntable motor, underneath the floor of the microwave; the turntable coupler, which is like a small plastic piece; the turntable support, either a three-legged or circular piece with wheels; and the glass turntable tray.
It sounds like maybe your turntable support is missing?
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. Goldstar owner manuals can be downloaded here.
Aug 11, 2008 | Goldstar Microwave Ovens
Light and door spring
I had a tension rod break in my door as well. There are two of them that cross forming an X and you can see them when you open the door and look in the crack. Fixing them is very easy once you get the outer panel w/ glass and the black molded plastic piece off. WARNING, when you open the door there are two screw on the inside top part of the door assembly. THEY ARE THE ONLY TWO SCREWS HOLDING THE ENTIRE FRONT PANEL/GLASS ASSEMBLY IN PLACE. I found this out the hard way. When the 2nd screw disengaged the whole assembly came crashing down shattering the glass and nearly cut off my toe. Be very careful when taking off the outside panel!!!
Next challenge...the black molded piece that also needs to come off. To remove this take off the piece that surrounds the exhaust tube to get at two screws that are directly underneath the molded plastic piece. After getting that off you have access to the two rod and can get them installed without to much trouble.
Again, be very careful when removing the front panel. My repair went from an 18 dollar tension rod to a $200 dollar front panel and nearly cost me a toe (yes, I was barefoot).
Aug 07, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
GE Microwave vent fan replacement
(I'm assuming you're talking about the hood / vent / exhaust fan instead of the internal magnetron cooling fan).
The part # SMV-260UA-C will not be enough to go on, as there at least 3 variations on that number shown at Samsung parts.
These microwaves are made by Samsung, but you'd need the GE part number to replace the whole thing. They don't sell the blades separately.
The part # for the "ventilation motor" is WB26X10042 and you can find it for $97.11 here, which is about fifty dollars less than direct from GE.
I may have available a replacement flan blade off a used unit. If you'll send me the dimensions, I'll check. I need the length of the fan blade, the diameter, and the inside diameter / shaft size, and whether the shaft is round or "D" shaped.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave vent fan replacement.
The part # SMV-260UA runs just under $60 from SamsungParts, depending on which of three versions you choose. You can find them here.
And a simple Google search shows quite a few hits for "SMV-260UA" and they seem to run about $40, assuming the listings aren't bogus - as so many search results are.
I have a few "new old stock" and used vent & cooling fans here.
I would be happy to supply one whole or just the blades if you like.
Just tell me the dimensions: diameter of the shaft hole and the length and diameter of the "squirrel cage" itself and I'll see if one of mine would work.
Jul 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing door handle???????
gently pry the plastic from the inside working from the hinges to the corner. you will need to put something in place of the screwdriver when you pull it out to go to the next pry position (about every 2 inches. i use apex bits. you can use anything about the diameter of a cigarette. then the screws for the handle will be exposed . it all snaps back together.
Feb 18, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
First of all, if it's just the plastic (nylon) fan blade that's melted, most any fan blade should work. I'd take the blade and motor to a local appliance parts shop and see if they have just a blade assembly that would fit. Normally the shaft diameter is standard and the only consideration is to get a blade assy whose outside diameter and thickness are the same or a little less than the original. Concerning the original part # you gave there are 3 Samsung parts that match up on http://www.samsungparts.com : Part Number Description Specification Price DE31-10178A MOTOR-VENTILATION SMV-260UA,120V,60Hz,31 $67.78 DE31-10178B MOTOR-VENTILATION SMV-260UA-1,-,-,-,-,-, $70.09 DE31-10178E MOTOR VENTILATION SMV-260UA-N,-,-,120V60 $67.87 Lastly, if there happen to be any numbers on the blade assembly itself, you can check them to see if they're good numbers at http://www.samsungparts.com Good luck!
Dec 02, 2006 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
