Question about Lexmark X2500 All-In-One Printer
Computer will not communicate with printer
I have plugged and unplugged my printer and it has found the new hardware but will not let me print it says will not communicate with printer
    President:
  • 1,944 Answers
    Problem Solver:
  • 41 Answers
Download and reinstall the drivers for your printer. Just go to google and type in the printer model and "drivers".
Posted on May 25, 2008
Printer is on and plugged in but says it's offline
Once its showing there is no communication between system & printer. Check with another usb cable...Go to my computer properties # hardware # device manage # highlight any one of the list # action# scan for new hardware.. system will scan for new hardware, if its not found replace formatter....
Sep 27, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Canon mp600 printer wont print
check first if printer work fine, you can test print it manually, then check if computer communicate with the printer by allowing to remove driver and insert usb cable it must be popup that found new hardware occurred for its detecting printer. reinstall back driver, restart and send print test.
Mar 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
When I go to print it says communication not available. I have checked the cables and they are all plugged in properly
You need to cofirm that the printer cable is functional. Also you need to check that the printer is properly installed.
Try this:
1. Try another printer cable. If the problem persists then you are sure the cable is not the issue (Given that your are sure the second cable is working fine).
2. Unplug the printer from the PC, but leave it plugged to power. then restart your system. When it has booted plug the printer to the PC. You should see a "Found New Hardware" Message if the printer is not installed. If so you need to install printer. If the problem persists let me know.
Sep 19, 2009 | Lexmark X1290 All-In-One InkJet Printer
Port not recognized - printer and computer do not communicate
unplug printer ,shut down printer, shut down computer, then restart computer, and plug printer back in after computer is fully up and running turn printer back on
and that should solve the problem
Jul 20, 2009 | Lexmark X3650 Printer
Kodak G610 printer dock won's communicate with computer
You know I had this same problem for a while as well. The only solution I found was that I HAD to use the Kodak Easyshare software in order to print anything with it. (That was the case with my XP desktop and my Mac laptop...). But sometimes it still would not spool properly and would require unplugging the printer and plugging it back in to reset.
Jan 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
I cannot connect a dell 720 printer to dell laptop Inspiron 1501 (Vista). It says it is installed but a message comes up that communication is not available.
First, shut down your computer and priner. Unplug both from the wall outlet, Unplug the printer from the computers USB receptical. Next, plug both the computer and printer back into the wall, and turn on ONLY THE COMPUTER. After the computer is fully initialized, plug the printer into the computer's USB socket and turn printer on. A small window on your screen should say:NEW HARDWARE FOUND. it will ask if you want it installed, click on YES. and just follow the onscreen instructions, and make sure your printer driver is compatible with VISTA..To check, go to http://support.dell.com and left click on WINDOWS VISTA SUPPORT. Left click on LATEST VISTA DRIVER UPDATES, and follow the onscreen instructions to check what you have now, and what you may have to download.. If, after downloading and installing VISTA COMPATIBLE SOFTWARE,you still get the communication message, try this: On the windows screen, left click on START. left click on CONTROL PANEL, then left click on PRINTERS. Find your Dell printer icon and RIGHT CLICK on the icon.. On the drop down menu, left click on PROPERTIES. On the Properties window, left click on the PORTS tab. Make sure USB VIRTUAL PRINTER PORT FOR DELL is checked. If no, select that port, left click on the check box, also check ENABLE BIDIRECTIONAL SUPPORT and ENABLE PRINT SPOOLING boxes. Then left click on APPLY, then Ok. The Dell printer icon should show READY. Try a test print to check operation.
Aug 11, 2008 | Office Equipment & Supplies
LEXMARK 4200 SERIES
Hi anders2......
Check if u have downloaded the correct software from the website...there r tow versions for vista (64bit and 32 bit)...check if ur Vista is 64 or 32 bit and d\w the software.....
If u hvae downloaded correct printer then....
Check the USB cable..try different port...
Clear all the docs in the printer folder...
Remove the power adaptor and replung..restart computer..
When u unplug and replung the usb cable doesn ur computer give a pop up "found New hardware" ?...If it doesnt..then (Check if USB printing support,USB composite device are present in the Device manager...i.e Right click on "my computer" ikon-go to PROPERTIES-Hardware-Device manager-Click the plus sing near and check in the list )
U can also try...
Uninstalling the s\w....disconnect the USB cable..reinstal the s\w and connect the cable when it prompts to...
May 30, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer(2500) does not print
Does it Say Cannot communicate ...if yes then
U can also try...
Leme know if this fixed
May 26, 2008 | Lexmark All-in-One Printer with PictBridge
Lexmark Z645 Printer
i have a problem of Lexmark Z645 Printer i want a software of this .
Feb 09, 2008 | Lexmark Z645 InkJet Photo Printer
Yellow error light on, no display
Try plugging the usb into a different computer if new hardware is not found then the printer's hardware is bad. If new hardware is found on the second computer then uninstall and reinstall the printer driver on the first computer.
Jan 22, 2007 | Konica Minolta magicolor 2300DL Laser...
Lexmark X2500 All-In-One Printer Logo
71 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
