Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Mitsubishi Medallion Integrated 1080 Model 55613. We have a good picture for about 3 mintues then a series of vertical wavy lines appear. Once this starts, the lines do not go away. I have reset the TV and that did not help. We isolated it to the function of the TV versus Direct TV. What are your thoughts.
  • 1 more comment
  • rbosler2 Sep 29, 2010
    We have scheduled a technician. The tech told us that this model is only about 1/2 way into its intended life and well worth repairing.
    According to the authorized repair service we are using, this Mitsubishi model WS 55613 is only half way into its life expectancy and well worth repairing. This set is designed for heavy use and the repair estimate is less than we expected by a lot.
    Took care of the solution button, thanks for your help
    President:
  • 2,777 Answers
It is either the main board in the TV itself going bad, or the picture tubes starting to go bad, both of these things can cause the exact problem you describe. Regardless though it is an indication of major hardware failure, there is no simple reset for this. You will need to contact a local TV repair person in your area. If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
So sorry that I don't have better news but it is definitely a failing part in the TV...
Thanks
Tim
Posted on Sep 29, 2010
  • Tim Grayson
    Tim Grayson Sep 29, 2010
    Sounds good, and yes it is worth repairing for sure. If possible please make sure you come back to the question here and click the Accept This Solution button otherwise I don't get credit for the help.
    Thanks!
    Tim
Mitsubishi WS-55613 55in.
1. "wavy" may mean a signal problem inside the set--are you seeing colors out of position or skewed around letters etc?
2. Does it do it when a DVD is played? (this will rule out certain things).
SD TECH
Apr 21, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Model # ws-55613, a short time after the tv turns on there are wavy vertical lines that wont go away. if i turn off the tv and restart it will work for a short time and wavy lines will reappear.
The WS Mitsubishi has a known problem with the Power Supply electrolytic capacitors and the electrolytic caps on the DM board. See my tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer for more detailed information. The problem you are describing would be the first part of the known problem. There are several repair/replacement choices listed in my tip.
Thanks for using FixYa and for the great rating.
haradrocko
Jun 16, 2011 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi Medallion - The green convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 15, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Wavy horizontal lines running through the screen
Ur tv convergence is dead.U must know how to solders?The 2 STK convergence ICS.and some or all it resistors must change.Tries websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 17, 2010 | Mitsubishi WS-55613 55" Rear Projection...
My Mitsubishi Medallion 1080 won't turn on
Are you sure its the right remote? Verify TV mode on remote if equiped with mode switch. Drain the remote by removing batteries.
Jun 27, 2009 | Televison & Video
Mitsubishi 1080 HD Medallion
If the LED doesnt light. Check the fuses. the fuse many be blown. Unplug the set before you check the fuse.
Jun 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
May 30, 2008 | Televison & Video
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
525 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
