Question about Samsung SL420 Digital Camera
The power goes on and the lens pops out but then it switches off fast
    Brigadier General:
  • 3,006 Answers
Your camera almost certainly has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Samsung service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 29, 2010
My Lumix DMC FS5 is not working
My Lumix does that when the battery is too low.
Jul 31, 2014 | Panasonic Lumix DMC-FS5 Digital Camera
Where is the on off switch on canon 75mm-300mm is usm
There isn't one The lens is powered from the camera battery and when the camera is switched off no power goes to the lens. So in effect the off switch is on the camera.
Jun 23, 2012 | Canon EF 75-300mm f/4-5.6 IS USM Lens
Errer #45 kodak v610
The problem seems to be with your lens guide it is out of track so please follow the step below,
Try forcing the camera lens but be careful while doing this if something goes wrong your camera our lens can be damage
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
If no luck then contact your Kodak service centre
Thank You
Oct 01, 2010 | Kodak EasyShare V610 Digital Camera
Turn on camera,lens pops out,goes in/out focus reads lens error
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 15, 2009 | Nikon COOLPIX L18 Digital Camera
I have a sony camera DSC w30, when I switch it on, the lens comes out and goes back in, this happens twice and than a message pops up to restart the camera and same thing happens again
This is problem of lens mechanism and complete lens assembly will be replaced to correct this error.
Please check with local camera repair shop for lens assembly replacement.
Oct 17, 2009 | Sony Cameras
Sony camera
ok to fix this just switch on
gently pull and twist the end of the lense you may here it click but dont pull or twist to hard till it pops
then switch camera off and on again and you should have solved the problem.
hope this helps
Sep 10, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Aiwa nsx k570
i need the circuit diagram for the CD player in NSX K 570 Aiwa 3 CD changer music system . I am Located in mumbai colaba. 9819890987
Mar 18, 2008 | Audio Players & Recorders
Fujifilm A700
hi use a fuji s5600 which is ok for my need's but also the batteries are very fast down, i checket it to contakt for the battery is not good my tip clean out the battery shelf and try to tighten up the small srews inside, may open it and close again and you can use a power messure if the power goes true or not. sorry my english...
Sep 22, 2007 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Camera switches itself off seconds after turning it on
This is a service center job and I think the lens assy motor is jammed. Take to a near by camera repair center
Feb 04, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Samsung SL420 Digital Camera Logo
89 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
