Question about Poulan 2-Stroke Engine Oil - 24 Pack
Her chee fun 50 scooter. when trying to accelerate the engine "dies". have had a new ecu and magneto fitted, carb stripped and cleaned, fuel tank drained and cleaned then filled with fresh fuel. when the air filter pipe to the carb is almost blocked( thumb over in-pipe) the engine will run ok. any suggestions would be great
    Problem Solver:
  • 10 Answers
Assuming everything is back toether properly and was not the problem the frst place, remove the exhaust pipe to expose the exhaust ports to ensure they are not carbon block. Also check the exhaust it self for a spark arrestor screen that could hve been carbon fouled and clogged. Cannot free flow because of the problems noted above, you will not be able to run a two-stroke engine reliably.
Posted on Sep 30, 2010
MC Dies upon ANY throttle application. HELP!
Odds are that if it sat for a year with fuel in it, the carb may be gummed up. Opening the throttle will cause an immediate engine stop if it is not getting fuel.
I'd recommend a "clean out the carb" project, including using air to blow out allof the small orifices.
Jun 29, 2015 | 1996 Honda VT 600 C Shadow
Boggs out with acceleration.
Hi Suzanne, a common fault with automatic scooters is the transmission or clutch. Your scooter has a centrifugal clutch which contains rollers, these rollers tend to wear flat over a period of time. You would need to remove the outer left side engine cover and the 'front' clutch to inspect the rollers. Unless you have an air ratchet gun to remove the crankshaft nut i would bring it to a dealer. Rollers are about 20 euros and the job shouldn't take more than a half hour, once they have your scoot on the ramp! Also check the condition of the air-box itself, make sure its not cracked/broken and connected properly to the carb, with an air filter fitted. Scooters make so little power that any change or variation in this area can seriously upset the fueling. Lastly check your spark plug and gap, must be clean and gap no bigger than 0.07-0.08mm. Best of luck..
Dec 01, 2013 | 2008 Adly Thunder Bike 50
My roketa 2007 maui 50 will start run then die and when i get it to run it only goes 10- wo miles an hour . I have new carb , plug and new fuel filter. What could be the problem?
A few things it could be, Dirt in the fuel line, or tank strainer is mostly clogged. Pinched fuel line. Plugged tank vent. Spark plug not gapped correctly, poor quality fuel, old fuel, 87 octane fuel that is more than a few weeks old.
It can also be a faulty magneto.
Nov 01, 2012 | Cars & Trucks
Scooter starts but turns off
Hi, Domagoj and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have nice a day.
Scooter Troubleshooting Scooter won run All about Scooters
2 Stroke Carburetor Rebuild Rm 250 Part 1
Two Stroke Scooter ATV Carburetor Settings And Adjustments 1of4 Basics...
http://absolutelyscooters.net/service-manuals.html
CPI Scooter Parts Racing Planet USA
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 26, 2012 | Cpi GTR 50 Motorcycles
Taizhou 50 quits running while riding
Hi, T and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, stator, magneto, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Air/fuel mixture screw improperly adjusted.
11. Accelerator pump damaged or not working.
12. Water or dirt in the fuel system, carburetor or filter.
13. Restricted, blocked or kinked fuel line.
14. Fuel tank empty.
15. The gas cap is not venting properly or fuel tank venting system blocked.
16. A failed fuel pump, pressure regulator and or fuel injectors.
17. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
18. Petcock clogged or damaged.
19. Needle and seat stuck closed in the float bowl.
20. Lean angle switch is faulty or needs adjustment.
21. Catastrophic engine failure, perform a compression test.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Please Help Engine Dies While Driving
Scooter keeps cutting off while driving SCOOTER PROFESSOR
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Chinese Scooter Parts Diagrams
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Nov 12, 2017 | Motorcycles
The engine misses on acceleration above 6K revs. New spark plugs Air filter fitted. Carbs cleaned. At low revs and speed engine is smooth. On acceleration appears to die and pick up againbut worse as...
what kind of bike is it?what style of carbs? if it has rubber diaphragms in the tops of the carbs, you might have a pinhole in one or more of them.
May 16, 2010 | Motorcycles
My wife has a 150cc TnGo verona scooter. It sat
You have enough 2 stroke in the fuel? 50:1 ratio oil:fuel or more... it is a cheap engine needs extra lubrication..
Is the spark plug clean? --- Is the HT lead connector to the sparkplug fine or has it come loose? --- Check the air filter - it could be wet or dirty or clogged - replace it if it has gotten wet or is dirty, on such a new bike it should look white as the driven snow... --- spray some carb cleaner down the intake while cranking the engine, and rev it up while spraying the cleaner in there, maybe you have some gunk in the carb messing up the jetting. --- Adjust the Idle screw to increase the idle (but not so high that the bike is tugging to ride off) --- Check through that lot and tell me how you get on.
Jan 25, 2010 | 2005 TN'G Verona 150
Buell blast is backfiring. Sat for 2 years so, cleaned fuel tank and cleaned carb. It will start now but is backfiring and will die of I try to idle. Thanks
If you did not completely disassemble the carb and remove all jets/emulsion tubes/needle valves then you did not clean the carb adequately. You could try adding either Seafoam, the Yamaha CARB-CL-EAN-ER, or Techron fuel system cleaner in an auxiliary gas tank and running the engine for a short while to ensure the mix gets into all the nooks and crannies. Let it sit for a couple hours to do the work, then drain out the float bowl, hook up the bike's gas tank and see what happens. Otherwise you need to remove, strip, clean, reassemble, and reinstall the carb.
Feb 26, 2009 | 2001 Buell Blast
Poulan 2-Stroke Engine Oil - 24 Pack  Logo
595 people viewed this question
Top Poulan Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Poulan Electrical Supply Expert? Answer questions, earn points and help others
