Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Whirlpool Accubake self-cleaning oven. Door locks but keeps making a clicking noise. Than E1 F5 comes up and the door stays locked even when I turn it off on the panel.
  • 15,935 Answers
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@$#WR
Posted on Oct 01, 2010
I have a whirlpool accubake self cleaning oven.. when trying to use the self clean option it now states e1 f5 in the digital screen what do i do know?
Most commonly that is a runaway temperature error which usually means the temperature probe is bad and needs to be replaced. If you need more detailed instruction or help making this repair visit the link below:
Appliance Repair Help With Live Chat
Mar 26, 2017 | Whirlpool Ovens
I'm getting an E1 f5 error code and my oven won't light
The F5-E1 error code means that their is a problem with the switch on the self clean door latch...it (the switch) is telling the control board that the door is locked even though it may be open so it will not let the oven come on
GENE
Nov 14, 2011 | Whirlpool SF325 Gas Kitchen Range
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. info@fixyourboard.com
Mar 20, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My Whirlpool Accubake super capacity 465 self-cleaning oven does not work. When started E1 -F5- appears on screen. Model# RF 386 PXGO. Serial# RJ0525903.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%#FDG
Jan 02, 2010 | Whirlpool Accubake RF362LXTT Electric...
E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Apr 07, 2009 | Ovens
Self cleaning F5 error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$TRE
Feb 23, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
Wont lock in self clean
Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
Oct 10, 2008 | Thermador C302U Electric Double Oven
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
343 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
