Question about Motorola Mobility E815
Motorola e815 problems
Motorola e815 gets hot when charging. says charged complete but will not last just one day
  • 282 Answers
First check your battery if its still in good condition.
Posted on May 25, 2008
Phone will not start when i try to start it with the charging cable it goes to a blue screen with the motorola symbal
Most Motorola phones don't work with the charging cable plugged in, as a safety measure. Unplug the charging cable from the phone and it will start working.
Sep 05, 2011 | Motorola Mobility E815
I just bought a motorola E815 cell phone and it will not charge
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.Hope this helps!
May 08, 2010 | Motorola Mobility E815
Walkie talkie batteries don't last
The Batteries that Motorola uses will die after a while mainly because people leave them on the charger all of the time. But there is a way to refresh them. You let the battery die completely, then you charge it up for about 12 hours. Then you let the battery die completely. Do this a couple of times and the batteries will last long.
Also, Motorola use to make a battery refresher (or did when I worked there.) It will charge and drain the battery automatically. It will even give you a fault if the battery is completely dead. For the HT1000 (for example) it would be the WPPN4065BR.
For future reference, don't constantly charge a battery. Only have it on the charger when the battery is actually dead or very low. This will increase battery life.
Mar 25, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
My E815 'end call' key wont work. cant turn my phone back on.
the phone uses a complete keypad for all the buttons you may need to replace tne whole keypad flex assembly. if you can take apart the phone you can purchase the flex on ebay. if not contact your local cell phone tech or you con contact for a repair estimate.
Nov 08, 2008 | Motorola Mobility E815
Motorola E815
Leave it on charger on a while. And then turn on.
If no luck try to open and clean it inside.
If than is not enough phone have not contact with power.
That is usually for old phones just don't turning on.
Jul 24, 2008 | Motorola Mobility E815
Motorola E815 Cellular
It sounds like one of the charging prong contact is lose inside.
to determine this turn off your phone and try to put it to charge.
if the phone powers up by it self. then that is the issue. and only someone with the right tools and knowledge can solder the contact/connector back the the main board.
If any questions please ask.
Jan 03, 2008 | Motorola Mobility E815
E815 won't hold a charge
It seems to be a glitch with this phone model. I am on my 3rd E815 and keep having charging problems and power cycling problems. I have to take mine into the store next week to exchange it for a new one (which most likely will keep doing the same thing). Best of luck to ya.
Dec 20, 2007 | Motorola Mobility E815
Motorola E815 flashed to Cricket
you need to get that charging port repaired. can replace the charging port with a new on for $55.
Dec 06, 2007 | Motorola Mobility E815
Motorola E815 - Battery Charger
I had the same problem but for some reason was able to use one of those Energizer battery chargers but no others!! I took it to Verizon and they cleaned the pins. Try using a toothbrush to clean it. That worked for awile then stopped. I took it to them againa and since it was still under warranty, they gave me a new one!
Aug 21, 2007 | Motorola Mobility E815
My phone whon't charge
Dear open ur phone and check the status of charging jeck where u put the charger if desolded sold will ok. other wise check the continuity of the charging fuse if it shows 0 oham then good other wise replace it.
Feb 18, 2007 | Motorola Mobility E815
Motorola Mobility E815 Logo
94 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
