Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Timed program stopped while 21 minutes remained
    Novelist:
    Champion:
  • DISH Network Expert
  • 286 Answers
Hello there! This is Becki Barned with Dish Netwoek customer service. There are a few reasons that could have happened. There could have been an event trying to record that stopped it, there could also have been someone trying to change the channel that accidentally stopped the recording. It could have been an issue with the DVR itself. If you have any other issues.
Posted on Dec 25, 2010
The dishwasher doesn't finish the 30 min program. The display shows 1 minute remaining but the washer doesn't stop.
It sounds like the d/w has a heating issues. Possible internal failure of the heating relay.
Jun 20, 2016 | Dishwashers
Gorenje washing, why does it stop with 1 left ?
Your NOT suppose to "Program anything". Machines are kinda like people. After they work, they need "some" time to rest. Your machine (And Mine) all do this. Next time leave it alone, the minute will count down and it will automatically shut off. Question? You actually stood by the machine and watched the entire cycle? Was there another problem that motivated you to do this? Like your clothes were still wet or water still in the tub?
Jul 26, 2014 | Washing Machines
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
Kenmore he2plus what's troublecode f-21
F21 on the tech sheet says Long Drain If the drain time exceeds 8 minutes the water valve turns off.
NOTE: After 4 mins the "Sd" error will be displayed then 4 mins later the f/21 error code will be displayed.
Press Stop two times to clear the display.
(Solutions:) Check drain hose
unplug washer and check electrical connections at pump
Check filter for foreign objects
If these fail it says to replace pump.
Dec 11, 2011 | Kenmore Washing Machines
F-21 code several times. We clean the pump. Start again the rinse/drain and spin cicle, and now present sd code and later f-21 code. What we need to do.
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
F21 Code and door remains locked after unplug and restart same thing
Hi, If the drain time exceeds 8 minutes the water valves turn off. NOTES: ■ After 4 minutes the “Sd” error will be displayed, then 4 minutes later the “F/21” error code will be displayed. ■ Press STOP two times to clear the display.
Possible Causes/Procedure: 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 12, 2010 | Kenmore HE3T Washer
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
Water isnt sucking out
code 21 means
Long Drain
if the drain time exceed eight minutes,"F 21" will be displayed, the water valve will turn off and the pump will stop running.
Press PAUSE/CANCEL to drain the machine.
The display will cleared and the machine will turne off after a maximun of eight minuts.
Was this helpful?
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
F-21 on my window
F21  mean LONG DRAIN if the dreain time ixceeds 8 minutes the water valve turn off. *After 4 minuts the "Sd" error will be do;[;aied tjem 4 minuts later the        F/21 error code woll be displayed. * Press STOP two times to clear the display.
if this wont work the following mus be done by a technician.
Was this helpful?
May 09, 2009 | Kenmore HE2 Plus Front Load Washer
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
150 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
