Question about Fujitsu Plasmavision P42VCA30EH 42 in. Television
Our Fujitsu plasma is around 7 years old and has developed a picture problem - a white band about 4 cm down the full length of the screen. On closer inspection it looks like 10 separate white vertical lines down the screen abot 4mm apart. It is not a permanent problem, but it comes and goes but is prevalent most of the time. I know plasma's have a finite lifespan - is this the beginning of the end or is there another explanation? Dave R
  • 3130 Answers
SOURCE: Black screen after 5 minutes of use with Fujitsu PDS-420 plasma
Sorry to inform you my freind, but the main board has to be replaced in this beast. Could get expensive. there are no schematics and or componets listed to repair this module. Its a board level repair only. Try going to, find their phone number, and see if they repair these boards. if not you will need to contact the manufacturer for replacement boards. good Luck Please do not forget to rate this thread.,
Posted on Dec 15, 2006
SOURCE: Fujitsu Plasma 42' approx 4 yrs old
HI , i have the same problem . it is either the power supply unit or the plasma display panel . I am problem solving it currently . generally the cost is about $1000 (aus) to fix . it is worth doing as fujitsu are outstanding plasmas .
if u need service manual pls email me at and will send service manual .it has the the checks to do so u know which part needs replacing . U need some experience to do the checks
hope this helps
Posted on Dec 21, 2007
  • 643 Answers
SOURCE: vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Posted on Jun 03, 2009
  • 534 Answers
SOURCE: Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu ''
Posted on Jun 05, 2009
  • 1039 Answers
SOURCE: fujitsu plasma tv is on but no picture
Check all inputs. Are they all dead. Try other signal source. Does antenna input work when connected to known good source?Vide input label being displayed indicates most of the tv is working. You need to determine if you have lost signal in the video input.
Posted on Nov 09, 2009
Testimonial: "Thanks so much! I feel like an idiot...not technical at all, and hubby is out of the country. You solved the problem, though!!"
Gt-s6810p screen
You can get the LCD screen for around 7 pounds and the digitizer for around 5 pounds on eBay. You can get most phone repair breakdowns at iFixit.
Oct 20, 2014 | Samsung Galaxy Fame GT-S6810P Smartphone -...
Surface area of a rectangular prism whose length is 7 cm.,width is 4 cm., and thickness is 5 cm.?
Since the 'base' and 'top' of any prism have the same shape, the surface area can be found by
  • surface area of prism = 2 * area of base + perimeter of base * H
So for the rectangular prism in your example..
  • surface area = 2LW + 2(L+W)H
  • = 2 * 7 * 4 + 2*(7+4)*5
  • = 56 + 2 * 11 * 5
  • = 56 +110
  • = 166 sq cm
Hope this helps
Sep 05, 2011 | Encore Math Advantage Algebra II and...
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Gas keeps going is it worth fixing or is a new one better
I assume you mean that your screen is showing signs of stress 7 the picture quality is suffering. This would mean a replacement screen is needed & as this is very costly then it is more economical to buy a new TV instead.
Dec 01, 2009 | LG 50PG6000 50 in. HD-Ready Plasma TV
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
Dark band 6 inches wide middle of the screen
Apr 10, 2009 | Televison & Video
Fujitsu Plasmavision P42VCA30EH 42 in. Television Logo
44 people viewed this question
Top Fujitsu Televison & Video Experts
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
