Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Doors ligth stay on when door is closed - Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
  • Kenmore Master
  • 17,129 Answers
Fault in the door switch which is shorting and keeping the lamp on , you will need to remove and replace as a cleaning even if this works may not last longer.
So wedge out the door switch and replace.
Posted on Sep 29, 2010
3 Suggested Answers
lenwest
  • 150 Answers
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
  • 28 Answers
SOURCE: Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Posted on May 09, 2009
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
Door ajar light comes on, chimes & it will not go off. My doors wills not lock anymore when shifted out of park and interior ligths stay on as well.
Hello: You have a switch in one of the door latch assemblies that is not working, Use of a up scale scan tool can identify which door. the only other way is to remove each door panel and trouble shoot each latch assembly.
Mar 09, 2011 | 2009 Pontiac G6
Doors ajar ligths stay on
i would advise you to replace switch on the door jam
Apr 06, 2010 | 2001 Ford F150 Styleside SuperCrew
Hello back door has been hit and fixed but it says door ajar and the ligths come on and dont know what wire to cut to stop that
when you close the door it brakes a ground this is how the light goes out.sometimes it can be adjusted.if you can push the button in while the door is open then that is your problem and you probably need a new door jam switch.
Aug 03, 2009 | 1995 Dodge Caravan
1998 Ford Windstar fuse problem - dome light stays on etc
you most likely have a bad door ajar switch- the door panel has to be removed to access it, its on the door latch- you can unplug them this will take care of the batt drain prob.as for the locks it may be a switch problem- most ford vehicles will not let you lock the vehicle from the driver's door when it's open to prevent locking the keys in.
May 26, 2009 | 1998 Ford Windstar
Right door will not stay closed
Put vaseline on door seals
May 26, 2009 | Maytag MSD2758GEW
Tachometer swings wildly - door ajar light stays on
check the peed sensor wires. is on top of the tranns o may be on the side this sensor is bolted in the transmision w/ 10mm. imprety sure is los for the second q?? check firts the bulb put a new one. check you fuse(s). if the door ajar istays on check the pin is close to the brake pedal o by the door this is hold it by one nut problably fall of and this pin is inside thechasis area against to the chasis. kepin on you ligth
Jan 13, 2009 | 1997 Nissan Maxima
Printer problem
try this : open door, hold down go button, all lights will blink when stopped, close door.
If no response most likely bad fuser.
Dec 25, 2007 | Office Equipment & Supplies
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
42 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
