Keeps going off every 15 minutes then showing no signal
  • 17,130 Answers
Please check if the fan filter is clogged or the lamp heat is too much. If so the lamp can shut off, so use a good cooling fan to see if the shut down stops, if not the projector power or the lamp circuit must be checked for a loose connection., or possible power supply load breakdown.
Posted on Sep 29, 2010
How do I stop my washing machine door alarm
go to instru.manual section troubleshooting and fix it. God bless you
if doesnot have it download from www.fitness.manualsonline.com
However try this.
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint Ultima WF860 Front Load Washer
Our new digital LCD tv occasionally suffers from picture breaking up and even total loss of signal, after some time, 5 to 15 minutes the signal is restored. Fiddling with the aerial run and connections has...
Tune to a strong channel.
Go into the menu. Find the Channel or Antenna whatever your tv calls it. Set the signal strength display.
If the signal strength show good and your picture is lost then a problem may be in the tv.
More than likely the antenna is not picking up a strong signal. Try rotating it some.
You can go to www.tvfool.com to see what stations are in your reception area.
Feb 13, 2011 | Televison & Video
My car keep stoping after 15 or 20 minutes
Same symptoms can happen if the crank sensor is going bad. You need to test it when it has died or the reading may show it's good. Good test procedures can be found in haynes or chilton manuals (I prefer chilton as their diagrams seem to be better.)
Crank sensor may set a code in the computer. Most of the larger parts stores will do a free scan test. That should give you some direction.
May 10, 2010 | 2000 Jeep Grand Cherokee
Tv takes forever to turn on sharp television LC-32SB23U
This problems very common with sharp tv.The Main Turner Signal board have problems.Keep using it,when it stop and completely dead 20-30 on-off no backlight show up and picture.U know ur Tuner board signal board is dead, have to replaced it.
Jan 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
My Tom Tom One takes a long time to pick up a GPS signal (30 to 45 minutes)
You might want to try updating your TomTom through TomTom Home. It loads something called "QuickFix" onto the TomTom, which I guess tells the TomTom where GPS satellites are going to be. I get a fix in about 5-15 seconds if I keep this updated, otherwise it takes a few minutes.
Aug 01, 2009 | Tomtom One XL GPS Receiver
560 people viewed this question
jasbo
jasbo
