Question about Hotpoint Aquarius WMA42 Front Load Washer
I have a hotpoint aquarius 1000spin wma34 model no:ako 547 005. my problem is the load will not run all the way through without flickin the door lock light on and off and the wash load is all mixed up. i have changed the door inter lock and the door catch lock but it is still playin up. i think its the control panel?????
SOURCE: Hotpoint Aquarius WMA34
there is a small access panel in all front loaders.  there is probably a coin stuck in the compartment.  this will stop the water pump operation correctly
Posted on Oct 27, 2007
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Posted on Nov 02, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius wma34 washing machine - flooding and clicking
Sounds like it could be relatively expensive to put right.
Personally, I think you would be better in investing in a new washer, more so in view of the fact that is 7 years old.
There are numerous possibilities for the symptoms you describe.
Hope this helps you to come to a decision.
Posted on Dec 29, 2009
barkencoa
  • 3463 Answers
SOURCE: The door catch on my Hotpoint Aquarius WT540
You need to seperate the 2 halves of the door, remove all screws securing the 2 halves together, and prize apart.
You will then see how all the parts are fitted.
SOURCE: control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Posted on Feb 16, 2010
Hotpoint Aquarius WD63 door won't open
on some hotpoint models you can remove the front kickplate and on there will be a yellow or green plastic pull toggle, pull this and it will bypass your door lock, if your appliance does not have this then you will need to unplug and leave unplugged for 10-15 mins to reset the door lock, you will however more than likely need a new door lock
Apr 07, 2014 | Hotpoint Aquarius WD63 Front Load...
Hotoint WMA34 door light keeps flashing and machine wont start
The light flashing usually indicates that the door is not closed securely. this can be caused by a weak or broken door handle spring.
If you are satisfied that the handle is o/k, then the other possibility is that the control module has a blown track, this can be accessed by removing the top cover.
Hope this nhelps.
Jan 15, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wma34 washing machine - flooding and clicking
Dec 29, 2009 | Washing Machines
Washes but does not spin
I AM NOT A MECHANIC, BUT IT SOUNDS LIKE YOUR MOTOR COUPLING NEEDS TO BE REPLACED.
May 13, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Drum makes grinding noise when turning
Hi.
spin the drum by hand, if it feels rough or is noisy, then you probably have drum bearing failure.
Another possibility is one or more of the drum paddles may have come adrift..
These can be replaced.
Nov 24, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Wiring Diagram
Have you looked under the main control panel for this??The other way is to contact Hotpoint(GE) support,they will have this information.Just have model & Serial number ready.
Jun 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius model wm62
Sounds like a faulty door interlock (quite a common problem)
UNPLUG POWER first, remove lid, remove screws holding door lock in place and lift lock assembly up, replace door lock, ensuring cables are replaced in the correct order. Refit and test.
Good luck.
Nov 11, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Oct 27, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA34 Where to find the motor to change the brushes
DON'T FORGET TO UNPLUG THE POWER FIRST!
Remove the lid and the motor is sat to one side on top of the drum.
Oct 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
120 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
